Cdelosu Posted September 28, 2009 Posted September 28, 2009 The security system on my 99' Accord is having some issues. Whenever the key is in ignition and the doors are closed, the security system arms and the doors lock, even without hitting the lock button. If I unlock the doors, after about 10 seconds, they re-lock and security gets armed again. Everything used to work just fine and ive really done nothing to the car!? Anyone see this before?? Local honda service center was a bit puzzled on the phone and they said to bring it in. I don't want to do that if its a quick reset or something. Appreciate the help!!
SpeedDemon Posted October 2, 2009 Posted October 2, 2009 sad thing is....is it probably will need just a quick reset
Cdelosu Posted October 2, 2009 Author Posted October 2, 2009 Thanks roopert, you solved everything Unhooking the battery, which I would consider a "quick reset", does not fix the problem. I know little about the alarm system. Is there a way to disable the alarm and re-enable for a reset.
2tone2owners Posted October 9, 2009 Posted October 9, 2009 Is this the factory alarm system? If not it sounds like you have ignition controlled door locks turned on passive arming.
zimmy709 Posted November 5, 2009 Posted November 5, 2009 Is this the factory alarm system? If not it sounds like you have ignition controlled door locks turned on passive arming. hahahahaha that's funny, i come in to say the same thing... and it's you who beat me to it. oh, and i agree.
lceah Posted November 5, 2009 Posted November 5, 2009 Try resetting the ecu by taking the battery and fuse out for a minute and then back...
