moody285970 Posted September 27, 2009 Share Posted September 27, 2009 Does anyone have an idea what could cause your front left wheel inner brake pad to wear prematurely? The rotor is warped also. The caliper appears to be fine. You can grab it and move it back and forth on the guide pins and when you change the pads, you can push the piston in without binding. A friend of mine at work stated that on two of his cars, he changed the brake booster and it fixed the problem. Some how the booster kept a small amount of pressure on his master cylinder, and thus on his front left caliper and rear right drum because they were the first in line to receive pressure from the master cylinder? Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted September 29, 2009 Share Posted September 29, 2009 Could be the booster, but also be sure the piston is clean. Quote Link to comment Share on other sites More sharing options...
