drive2ride Posted September 27, 2009 Share Posted September 27, 2009 Alright. Heres what I have and what is going on. 1991 Honda Civic dx 1.5 power everything. The car will turn over but will not fire. When i try and start the car after it has sat for a few days it will start to fire the FIRST time I crank it over, but it never successfully starts. Sometimes it gets close. After the first "almost start" it just cranks over with nothing. As for codes from the check engine light, I dont have any, I got the car with no battery. Heres what I have checked. Compression - Good. Timing Belt - Good. Timing - Good. Fuel - Good. Spark - Good. Ignition Coil - Good. MAP sensor - Good. Main Relay - Most likely good.(has 3 clicks like it is supposed to, resoldered it anyway and still checks out for clicks. ECU - Most likely good.(Has the first blink, pulled the ECU and it looks and smells brand new) I looked inside the intake on the intake manifold, and it sprays some fuel when we try to start it. Fuel going to the injection system has plenty of pressure. Pulled the valve cover and timing cover and all the timing marks line up and look fantastic. I have no idea why it won't start and dont understand how it can have fuel, spark and timing and not fire up. Any help would be much appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
injectedPois Posted September 28, 2009 Share Posted September 28, 2009 Vacuum leak? I can't think of anything else (maybe your battery terminals??) since everything else was good. I'm stumped man. Quote Link to comment Share on other sites More sharing options...
adamEj6 Posted September 28, 2009 Share Posted September 28, 2009 is the first blink on the ECU a long one? if so its a code 10 which is IAT, intake air temperature. Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted September 28, 2009 Share Posted September 28, 2009 have you checked your cap and rotor? plug wires? your whole dist. could be bad kuz your not getting any spark at all and if your coil checks out doesnt mean your gna get spark through the dist. could be a cold start sensor. could be that you have a vacuum hose on wrong on the tb that would make it not fire up at all if thats the case, if im not mistaken there is 1 or 2 hoses that would do that if you mix em up on accident. Quote Link to comment Share on other sites More sharing options...
drive2ride Posted September 28, 2009 Author Share Posted September 28, 2009 I have spark. I tested the compression and spark again yesterday. And compression is good. Every plug will spark away too, but it seems a little slow? if thats possible. The first blink on my ECU isnt a long one. I am going to probably swap the igniter next and see if that does it, but when im trying to get to it, it almost seems impossible to get to inside the distributer as there is stuff in the way of the two screws holding it down. Im very stumped and frustrated at this point. Ive swapped a bunch of parts and still get the same thing. It almost fires on the first crank (after sitting for a day or so) then it just cranks after that. Ill have to check the cold start sensor too. Quote Link to comment Share on other sites More sharing options...
drive2ride Posted September 29, 2009 Author Share Posted September 29, 2009 Where is the cold start sensor on a 91 civic? And what is it called at the auto parts store? cause it sure isnt called a cold start sensor, i cant even find that part for it online Quote Link to comment Share on other sites More sharing options...
cranny Posted September 30, 2009 Share Posted September 30, 2009 cause it doesnt exist. even though you have spark buddy , it doesnt mean there isnt something wrong with the delivery be it un-timed or weak. try a known working distributor. Quote Link to comment Share on other sites More sharing options...
drive2ride Posted September 30, 2009 Author Share Posted September 30, 2009 im going to run a timing light on it today or tomorrow to check and see if its timed correctly. I assumed the "cold start sensor" was just a honda name for a part that everyone else calls something else, kind of like the "igniter", when everyone calls it the ignition control module i always hear honda junkies calling it "igniter". Quote Link to comment Share on other sites More sharing options...
