Intrivic Posted September 26, 2009 Share Posted September 26, 2009 ok so i am helpin my friend swap an h22 into her accord. we had an idle issue cuz the throttle cable needed to be adjusted and the motor Ran AWESOME. we fixed the idle problem left it for the night and the next day we come back and there is a miss fire we changed fuel rails, injectors, spark plug wires, spark plugs. and nothing it still miss fires it has 180-190 compression all across the board we are getting spark and the injectors are working but when you pull cylinder 1's spark plug nothing happens the motor doesnt pick up and the motor doesnt bog any. and when you pull the number 4 spark plug the motor runs better. we have been workin on hondas for about 10 years and this is one for the ages i need some ideas. we changed ecus, we check wires for shorts and we cannot figure it out at all. i need info AS FAST AS POSSIBLE PLEASE. it was runnin like a champ the day before any ideas? Quote Link to comment Share on other sites More sharing options...
Intrivic Posted September 27, 2009 Author Share Posted September 27, 2009 so nobody has any ideas at all we just changed the fuel pump now and that didn't work either if anyone has anything they think might help let me know Quote Link to comment Share on other sites More sharing options...
James Matteu Posted September 28, 2009 Share Posted September 28, 2009 Check the Distributor Timing with Timing Light. Quote Link to comment Share on other sites More sharing options...
