Familiar with the 09si?? sedan??
09fourdoorsi
Posted
so im new to this forum.. i was wandering if there is any way to take out the sub woofer which is a stock 10in and replace it with a 12in. if not, would i need to get a new radio or does the 2009 sedans come with dual output/input?
Posted
in all reality, throwing in a 12" sub that will actually match the already low power ratings you are getting from the stock external amp will not even be worth the effort. The output gain would be minimal if any.
stick with what you have, or go aftermarket. The problem with aftermarket is that in alot of cases, you have to rip everything out and replace it. So if cost is an issue. . .
