dantheman2009 Posted September 24, 2009 Share Posted September 24, 2009 I actually have a 95 honda civic with the 1.5 stock non vtec engine , i was wondering if i have to change the ecm on the vehicle if i swap the engine out for the D15B Vtec version of it. Is it required or recommended Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 24, 2009 Share Posted September 24, 2009 I actually have a 95 honda civic with the 1.5 stock non vtec engine , i was wondering if i have to change the ecm on the vehicle if i swap the engine out for the D15B Vtec version of it. Is it required or recommended I am thinking yes, because your current ECU does not support Vtec? Quote Link to comment Share on other sites More sharing options...
dantheman2009 Posted September 24, 2009 Author Share Posted September 24, 2009 well yeah its not a vtec so i will have to swap it out, do you know if it is a difficult job to do or pretty simple if follow directions correctly? Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted September 24, 2009 Share Posted September 24, 2009 dont try to wire if you dont know how and you should be good!! i actually think they make conversion harnesses for that kind of stuff use google and check it out Quote Link to comment Share on other sites More sharing options...
dantheman2009 Posted September 24, 2009 Author Share Posted September 24, 2009 dont try to wire if you dont know how and you should be good!! i actually think they make conversion harnesses for that kind of stuff use google and check it out oh ok thanks so much delsolsweetie, i will make sure to do so, and well i was just asking im not to bad with electrical stuff but i just wanted an opinion thank you Quote Link to comment Share on other sites More sharing options...
adamEj6 Posted September 28, 2009 Share Posted September 28, 2009 just get the ECU for the d15 then 3 wires for vtec. pretty simple sh1t. Quote Link to comment Share on other sites More sharing options...
