r.etheridge Posted September 23, 2009 Share Posted September 23, 2009 1.6L DOHC V-tec J-spec. The block has been bored to .030. Darton solid deck sleeves, Arias custom made pistons and rings, venom intake manifold, fuel injectors, fuel rail, and cam gears. Unorthodox under drive pulley set, Holley 68mm throttle body and fuel pressure regulator, Crower rods, street/strip cams, titanium springs and retainers, manley custom made valves, Air Mass comp blue headers, Jet performance worked the ecu to work with all aftermarket parts. Stage 2 port and polish, 5 angle valve job, port match manifold to head and throttle body to manifold done by Fox Lake out of CA. Cometic custom made head gasket( can withstand up to 150 shot of nitrous) 2 sets of zex nitrous spark plugs, energy motor mounts, moroso aluminum oil pan w/ pick up, brand new stock clutch in the box. MSD dis 2 ignition control module, Wiring harness, ecu, complete oem honda gasket set upper and lower motor, stock crank. I have many other stock parts for the B16A motor that are J-spec. I also have all receipts and paperwork to go along with this motor plus a factory honda manual. 6k invested. 0 miles on motor. engine, tranny, ecu, wiring harness. asking $3500obo. will meet surrounding states to GA. Will ship at buyers expense. can send pics to e-mail. Thanks for looking! etheridge_ryan@yahoo.com Link to comment Share on other sites More sharing options...
r.etheridge Posted September 23, 2009 Author Share Posted September 23, 2009 note: this is a 1996-2000 civic si j-spec Link to comment Share on other sites More sharing options...
OTiS Posted September 23, 2009 Share Posted September 23, 2009 double post noob. and ya gotta have 25 post minimum to sell Link to comment Share on other sites More sharing options...
