r.etheridge Posted September 23, 2009 Share Posted September 23, 2009 1.6L DOHC V-tec J-spec. The block has been bored to .030. Darton solid deck sleeves, Arias custom made pistons and rings, venom intake manifold, fuel injectors, fuel rail, and cam gears. Unorthodox under drive pulley set, Holley 68mm throttle body and fuel pressure regulator, Crower rods, street/strip cams, titanium springs and retainers, manley custom made valves, Air Mass comp blue headers, Jet performance worked the ecu to work with all aftermarket parts. Stage 2 port and polish, 5 angle valve job, port match manifold to head and throttle body to manifold done by Fox Lake out of CA. Cometic custom made head gasket( can withstand up to 150 shot of nitrous) 2 sets of zex nitrous spark plugs, energy motor mounts, moroso aluminum oil pan w/ pick up, brand new stock clutch in the box. MSD dis 2 ignition control module, Wiring harness, ecu, complete oem honda gasket set upper and lower motor, stock crank. over 6K invested in motor alone! This motor has 0 miles on it. I have many other stock parts for the B16A motor that are J-spec. I also have all receipts and paperwork to go along with this motor plus a factory honda manual. $3,500 obo etheridge_ryan@yahoo.com located in Georgia will meet surrounding states. Buyer pays shipping if need be. I can send pictures to e-mail addresses. Thanks for looking Link to comment Share on other sites More sharing options...
r.etheridge Posted September 23, 2009 Author Share Posted September 23, 2009 note: this is a 1996-2000 civic si j-spec Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 23, 2009 Share Posted September 23, 2009 not allowed to sell stuff in any section than the WTS section. get 25 posts then put it up for sale Link to comment Share on other sites More sharing options...
adamEj6 Posted September 23, 2009 Share Posted September 23, 2009 who the fukk would pay 3500 for a gay ass b swap? Link to comment Share on other sites More sharing options...
CIVIC92 Posted September 23, 2009 Share Posted September 23, 2009 1.6L DOHC V-tec J-spec. The block has been bored to .030. Darton solid deck sleeves, Arias custom made pistons and rings, venom intake manifold, fuel injectors, fuel rail, and cam gears. Unorthodox under drive pulley set, Holley 68mm throttle body and fuel pressure regulator, Crower rods, street/strip cams, titanium springs and retainers, manley custom made valves, Air Mass comp blue headers, Jet performance worked the ecu to work with all aftermarket parts. Stage 2 port and polish, 5 angle valve job, port match manifold to head and throttle body to manifold done by Fox Lake out of CA. Cometic custom made head gasket( can withstand up to 150 shot of nitrous) 2 sets of zex nitrous spark plugs, energy motor mounts, moroso aluminum oil pan w/ pick up, brand new stock clutch in the box. MSD dis 2 ignition control module, Wiring harness, ecu, complete oem honda gasket set upper and lower motor, stock crank. over 6K invested in motor alone! This motor has 0 miles on it. I have many other stock parts for the B16A motor that are J-spec. I also have all receipts and paperwork to go along with this motor plus a factory honda manual. $3,500 obo etheridge_ryan@yahoo.com located in Georgia will meet surrounding states. Buyer pays shipping if need be. I can send pictures to e-mail addresses. Thanks for looking what do i need to put a b16a2 in a 92 civic hatch. I also need a tranny for the b16 and clutch but other than that what else plz email me @ crimsoncrx@aol.com Link to comment Share on other sites More sharing options...
airjordan223 Posted September 23, 2009 Share Posted September 23, 2009 This belongs in the Classifieds section where there is a minimum requirement of posts to sell something. Please read the rules before posting. Link to comment Share on other sites More sharing options...
