nobody Posted September 22, 2009 Share Posted September 22, 2009 So i finally get my title transferred, i got my plates and insurance too. i take the car out to get the inspaction and i finally actually drive the car. my problem here is that the car shifts hard on 1st, rmp's really high before it goes into 2nd. my car is auto remember yeah weak w/e i got what i could get. so like the guy said my car failed cause the car rpm's too high before it shifts. whts wrong with ma tranny? is it just done for? need new fluid? anything can help me here. all my work, time, money, and effort went into this car and i failed the inspection and found out the tranny sux..... im not worried about inspection ill buy one but i just dont wanna have a messed up tranny. any sug? ohh and i also failed cause emmisions too anything on that? plz! Quote Link to comment Share on other sites More sharing options...
C92hatchX Posted September 22, 2009 Share Posted September 22, 2009 (edited) 5spd swap or just swap your trannies with one that works Edited September 22, 2009 by C92hatchX Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 22, 2009 Share Posted September 22, 2009 check that fluid first that use to be an issue in a taurus i use to have, fluid leaked and it shifted hard now also, the tranny in the taurus went out about 2 weeks after i sold it so you may be lookin at new fluid for a quick fix, but in the long run i would look at getting a new one Quote Link to comment Share on other sites More sharing options...
nobody Posted September 22, 2009 Author Share Posted September 22, 2009 yeah i wanted the 5 speed swap but not yet cause its way too early. so i guess ill just change the fluid if i found out how. Quote Link to comment Share on other sites More sharing options...
Tko Posted September 22, 2009 Share Posted September 22, 2009 remember to check the fluid with the trans in N and car running. Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted September 22, 2009 Share Posted September 22, 2009 (edited) WOOOO WHAT dont no how to change fluid in trans? thats cake to do man heres how. 1st you have to walk your happy a$$ to the local parts store and buy a new pan gasket a new oeml filter, and the correct trans fluid and you not just picking any old fluid off the shelf. k some steps for you prty easy 2 follow 1: get a oilpan or bucket to put underneath the car 2: jack the front end of the car up (either leave the jack under the car or put 2 stands under and pull the jack out) 3: get a socket wrench and unbolt the pan at a corner towards the back of the pan completely 4: slightly loosen up the other bolts and let the oil drain out 5: after the oil is drained out and is taken off inspect the pan for any metal shavings and then take the old filter out 6: clean the old gasket off of the pan completely to ensure a nice solid seal for the new gasket 7: bolt the new filter on and this is just a suggestion here but some ppl do this and some ppl dont but just take some blue RTV and run a small bead of it around the edges of the pan and then put the gasket on and right b4 you put the pan back on put some on the gasket its self and the bolt the pan back up (the RTV will ensure a nice solid seal and no leaking out of the pan). 8: fill your trany up threw the dipstick using funnel with a paper towel in it just to make sure you get no dust or any other oils and w/e inside the trans, itll take 4 ever but it works. and previously stated above make sure your trany is in neutral and the car is running after you put a qrt or 2 in so you dont burn your trans up. Edited September 22, 2009 by xxhrdcr4lifexx Quote Link to comment Share on other sites More sharing options...
nobody Posted September 22, 2009 Author Share Posted September 22, 2009 so its almost the same as changing the oil then am i right? Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 22, 2009 Share Posted September 22, 2009 pretty much lol. almost exactly except position of plug, type of fluid, tools needed. thats about your only difference Quote Link to comment Share on other sites More sharing options...
nobody Posted September 22, 2009 Author Share Posted September 22, 2009 hh i thought it be more sophisticated that why, kewl i check it out tomorro i guess i needa see wht all these codes are that the car failed.. Quote Link to comment Share on other sites More sharing options...
