d16z6 motor question....
i thought it was 5200 ish
im wrong too
D16Z6
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Rod Length : 137MM
+ Rod/Stroke : 1.52
+ Compression : 9.2:1
+ Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
+ Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
+ Volumetric Efficiency : 87.68%
+ Redline : 7200 rpm
+ Fuel Cut : 7411 rpm
+ VTEC Switchover : 5500 rpm[3]
+ Fuel Control : OBD-1 MPFI
+ Head Code : P08
+ ECU Code : P28
Edited by DelSolSweetie
im wrong too
D16Z6
+ Rod/Stroke : 1.52
+ Head Code : P08
+ ECU Code : P28
Mine is 4800RPM and is stock ECU, I got rid of a chipped ECu that had vtec set at 5800RPM, in favor of stock.
  • 3 weeks later...
it seems like it kinda kicks in at 4500 or 4600 but im a newbie.......i think the crossover does hit at 5500 though...it starts haulin after 5500 pretty good if im on it.if any though,thanks you guys....its a slow build but worth it....i love having a honda!!!!!!!!
