venomxx Posted September 18, 2009 Share Posted September 18, 2009 Im installing a remote starter system. As I go along, I'm sure I'll run into problems. I'm hoping to post this to get others to help me out. First problem so far is i can't find the Neutral Safety connector. I found these info on a site; Looking at the fuse box, there are a bunch of cords. Which ones is for the NEUTRAL SAFETY one ? ? Thanks 2001 HONDA CIVIC 4DR SEDAN Security Battery WHT + (+) IGNITION HARNESS Ignition BLK/YEL (+) IGNITION HARNESS Starter01 BLK/WHT + (+) IGNITION HARNESS AllDoorTrigger GRN/RED (-) DRIVERS KICK PANEL TrunkTrigger BLU/BLK - (-) DRIVERS KICK PANEL ParkingLights RED/BLK + (+) TO RIGHT OF STEERING COLUMN Remote Start Battery WHT + (+) IGNITION HARNESS Ignition BLK/YEL (+) IGNITION HARNESS Ignition02 BLK/RED + (+) IGNITION HARNESS Accessory01 WHT/RED + (+) IGNITION HARNESS Starter01 BLK/WHT + (+) IGNITION HARNESS AntiTheftType RF ACTIVATED SYS. AntiTheftSystem TRANSPONDER NeutralSafety LT GRN - (-) DRIVERS FUSE PANEL Tach BLU AC (AC) AT CONNECTOR NEXT TO BATTERY SpeedSense BLU/WHT AC (AC) PIN 25 AT PCM BEHIND FUSEBOX ParkingLights RED/BLK + (+) TO RIGHT OF STEERING COLUMN BrakeLights WHT/BLU + (+) AT BRAKE SWITCH ReverseLights GRN + (+) DRIVERS FUSE PANEL Horn ORG - STEERING COLUMN Doorlocks / Window PowerUnLock WHT/GRN - (-) DRIVERS FUSE PANEL PowerLock WHT/BLU - (-) DRIVERS FUSE PANEL DriverDoorMotor01 YEL/GRN + (+) DRIVERS FUSE PANEL DriverDoorMotor02 YEL/BLK + (+) DRIVERS FUSE PANEL Convenience HeadLights BLU/RED - (-) AT HEADLIGHT SWITCH Mobile Audio / Video Battery WHT + (+) IGNITION HARNESS Accessory01 WHT/RED + (+) IGNITION HARNESS Ground BLK - (-) RADIO HARNESS Illumination (+) RADIO HARNESS FrontLeftSpeakerPos BLU/GRN FrontLeftSpeakerNeg GRY/BLK FrontRightSpeakerPos RED/GRN FrontRightSpeakerNeg BROWN/BLACK RearLeftSpeakerPos BLU/YEL RearLeftSpeakerNeg GRY/WHT RearRightSpeakerPos RED/YEL RearRightSpeakerNeg BRN/WHT Control Modules Link to comment Share on other sites More sharing options...
awdpwr Posted September 22, 2009 Share Posted September 22, 2009 maybe call an audio shop and see if they will tell you they have all the diagrams. Link to comment Share on other sites More sharing options...
