93delsols Posted September 13, 2009 Share Posted September 13, 2009 i got a easy question for people that have used bondo my bro has a 93 del sol and on the rear passenger fender he wants to bondo a spot roughly a 6 inch area. most of the dent is pulled out and is pretty close to flesh still has the holes in it when the dent was pulled so my question is how long will bondo last and would it crack, or would it be better off cutting out the bad spot and welding on a piece of metal? Quote Link to comment Share on other sites More sharing options...
99maxi Posted September 13, 2009 Share Posted September 13, 2009 i got a easy question for people that have used bondo my bro has a 93 del sol and on the rear passenger fender he wants to bondo a spot roughly a 6 inch area. most of the dent is pulled out and is pretty close to flesh still has the holes in it when the dent was pulled so my question is how long will bondo last and would it crack, or would it be better off cutting out the bad spot and welding on a piece of metal? I would bring it to a shop to do, but if you want to do it yourself, try to get professional body filler, the finishing type since the dent is almost flush. If you mix the stuff correctly, it should last a long time. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 13, 2009 Share Posted September 13, 2009 should be fine with the bondo. just make sure you follow the typical procedure for bondo which is bondo, sand, bondo, sand, bondo, sand, bondo, sand, bondo, sand...... and rule of thumb, if you can feel anything, it will show up greatly once paint is put on. Quote Link to comment Share on other sites More sharing options...
Joe W Posted September 13, 2009 Share Posted September 13, 2009 should be fine with the bondo. just make sure you follow the typical procedure for bondo which is bondo, sand, bondo, sand, bondo, sand, bondo, sand, bondo, sand...... and rule of thumb, if you can feel anything, it will show up greatly once paint is put on. He speaks truth, body work isn't that hard just take you time and follow directions. Keep going till it's smooth and even then paint. Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 13, 2009 Share Posted September 13, 2009 Just as long as theres no rust involved and you do it correctly, unlike this guy! Wabnt to be entertained read that! http://www.hondaforums.com/index.php?showt...30328&st=20 Quote Link to comment Share on other sites More sharing options...
Mitchness Posted September 14, 2009 Share Posted September 14, 2009 (edited) God, I don't even need to click on that link to know what Pearce is talking about. bleh Edited September 14, 2009 by Mitchness Quote Link to comment Share on other sites More sharing options...
Tko Posted September 14, 2009 Share Posted September 14, 2009 Now I'm shocked to hear that someone who has been a "mechanic for 7 years" and makes "twice what I make in two weeks in one" and "drives in time attacks" knows nothing about Bondo or fixing dents. Anyways as I am the adult not the 17 year old here Ill help out with some information. You don't want to use Bondo for thin layers the stuff you want is called DuraGlass. My friend who owns a body shop swears by the stuff. For thin layers that you don't want to crack and want to look smooth Duraglass is the stuff you want not Bondo. Bondo is good for building up and shaping but for a show quality finish Duraglass all the way. Quote Link to comment Share on other sites More sharing options...
OTiS Posted September 14, 2009 Share Posted September 14, 2009 i just went thru the four pages of that and it kinda makes me wonder if that kid ever owned my car. Quote Link to comment Share on other sites More sharing options...
