Rickhonda Posted September 12, 2009 Share Posted September 12, 2009 Hi Everybody, I need help. It was a hot day, I try to start my prelude with one crank, as I crank, the engine turn but didn't start. After that, I can't get it to start. My battery is good, my starter is good...but I have no flow of power...no power to the ignition...now no electric flow anywhere, any help will be appreciate...thank you. Link to comment Share on other sites More sharing options...
H22A Prelude Posted September 13, 2009 Share Posted September 13, 2009 check the conections on the terminals Link to comment Share on other sites More sharing options...
Rickhonda Posted September 13, 2009 Author Share Posted September 13, 2009 check the conections on the terminals More details please...i checked the cable to the battery...etc...thanks Link to comment Share on other sites More sharing options...
Shanebot90 Posted September 13, 2009 Share Posted September 13, 2009 make sure the terminals are completely clean, is what he means. Both sides of the connection. remove the terminals and clean them off. maybe some sand paper or something abrasive. Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted September 19, 2009 Share Posted September 19, 2009 well your selenoid could be bad kuz when mine went bad it drained all the power to the whole car. might want to check the next after you clean you terminals up and theres still a prob. also check your fuses under your hood and under your dash inside the car, if nothing could be a relay or you have a grounded wire some where Link to comment Share on other sites More sharing options...
MikeDubs Posted September 20, 2009 Share Posted September 20, 2009 pop clutch downhill and get that thing up to autozone. then get them to bring out that thing they use to check batteries. they should do it for free. Link to comment Share on other sites More sharing options...
hondeffinate Posted October 25, 2009 Share Posted October 25, 2009 Hi Everybody, I need help. It was a hot day, I try to start my prelude with one crank, as I crank, the engine turn but didn't start. After that, I can't get it to start. My battery is good, my starter is good...but I have no flow of power...no power to the ignition...now no electric flow anywhere, any help will be appreciate...thank you. hey man under the steering column there is a red plug in a plastic box it is your main fuel and ignition relay thats what is sounds like because i have one doing the exact same thing and replaced it and no more problems you can check it by turning your key on and listening for the click from under the dash if it clicks that means its working if it doesnt well you can figure it out Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted October 30, 2009 Share Posted October 30, 2009 if you havent figured this out yet try swapping out ignition switches Link to comment Share on other sites More sharing options...
Pballer2005 Posted October 30, 2009 Share Posted October 30, 2009 check the underhood fuses as well. may have popped one of the major ignition or fuel ones. Link to comment Share on other sites More sharing options...
88prelude Posted November 2, 2009 Share Posted November 2, 2009 well your selenoid could be bad kuz when mine went bad it drained all the power to the whole car. might want to check the next after you clean you terminals up and theres still a prob.also check your fuses under your hood and under your dash inside the car, if nothing could be a relay or you have a grounded wire some where your solenoid is on your starter. but you arent getting any power whatsoever. so its gotta be a bad connection on the battery. also check your main battery fuse under the hood in the fuse box. i beleive its a 70 amp Link to comment Share on other sites More sharing options...
lceah Posted November 2, 2009 Share Posted November 2, 2009 fuses/battery Link to comment Share on other sites More sharing options...
