DelSolSweetie Posted August 24, 2009 Share Posted August 24, 2009 (edited) just so no one has to ask anymore or do a search OBD1 long flashes are the first number and short flashes are the second number (example: 5 long and 7 short would be code 57) Code 0 and 11 Electronic Control Module (ECM) Code1 Heated oxygen sensor A Code 2 Oxygen content B Code 3 and 5 Manifold Absolute Pressure Code 4 Crank position sensor Code 6 Engine coolant temperature Code 7 Throttle position sensor Code 8 Top dead center sensor Code 9 No.1 cylinder position sensor Code 10 Intake air temperature sensor Code 12 Exhaust recirculation system Code 13 Barometric pressure sensor Code 14 Idle air control valve or bad ECM Code 15 Ignition output signal Code 16 Fuel Injector Code 17 Vehicle speed sensor Code 19 A/T lock-up control solenoid Code 20 Electric load detector Code 21 V-TEC control solenoid Code 22 V-TEC pressure solenoid Code 23 Knock sensor Code 30 A/T FI signal A Code 30 A/T FI signal B Code 41 Heated oxygen sensor heater Code 43 Fuel supply system Code 45 Fuel supply metering Code 48 Heated oxygen sensor Code 61 Front heated oxygen sensor Code 63 Rear heated oxygen sensor Code 65 Rear heated oxygen sensor heater Code 67 Catalytic converter system Code 70 Automatic transaxle Code 71 Misfire detected cylinder 1 Code 72 Misfire detected cylinder 2 Code 73 Misfire detected cylinder 3 Code 74 Misfire detected cylinder 4 Code 75 Misfire detected cylinder 5 Code 76 Misfire detected cylinder 6 Code 80 Exhaust recirculation system Code 86 Coolant temperature Code 92 Evaporative emission control system OBD2 P1106 BARO Circuit Range/Performance Malfunction P1107 BARO Circuit Low Input P1108 BARO Circuit High Input P1121 Throttle Position Lower Than Expected P1122 Throttle Position Higher Than Expected P1128 MAP Lower Than Expected P1129 MAP Higher Than Expected P1162 HO2S11 Circuit Fault (Bank 1 Sensor 1) P1163 HO2S11 Slow Response (Bank 1 Sensor 1) P1164 HO2S11 Circuit Fault (Bank 1 Sensor 1) P1165 HO2S11 Slow Response(Bank 1 Sensor 1) P1166 HO2S11 Heater Circuit Fault (Bank 1 Sensor 1) P1167 HO2S11 Heater Circuit (VS+) Fault (Bank 1 Sensor 1) P1168 HO2S11 Label Circuit Low Voltage Fault (Bank 1 Sensor 1) P1169 HO2S11 Label Circuit High Voltage Fault (Bank 1 Sensor 1) P1201 Cylinder 1 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0301 P1202 Cylinder 2 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0302 P1203 Cylinder 3 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0303 P1204 Cylinder 4 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0304 P1205 Cylinder 5 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0305 P1206 Cylinder 6 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0306 P1241 Throttle Vent Control Motor Circuit 1 Malfunction P1242 Throttle Vent Control Motor Circuit 2 Malfunction P1243 Throttle Position Insufficient P1244 Closed Throttle Position Insufficient P1246 Accelerator Position Sensor 1 Circuit Malfunction P1247 Accelerator Position Sensor 2 Circuit Malfunction P1248 Accelerator Position Sensors 1 & 2 Improper Correlation P1253 VTEC System Circuit Fault P1259 VTEC System Malfunction, Rear Bank (Bank 1) P1279 VTEC System Malfunction, Front Bank (Bank 2) P1297 ELD Circuit Low Input P1298 Electrical Load Detector Circuit High Voltage P1300 Random Misfire P1301 Cylinder 1 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0301 P1302 Cylinder 2 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0302 P1303 Cylinder 3 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0303 P1304 Cylinder 4 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0304 P1305 Cylinder 5 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0305 P1306 Cylinder 6 Misfire - Compare possible causes/symptoms for this Honda check engine light code to the Generic OBD II code P0306 P1316 Spark Plug Voltage Detection Circuit Malfunction, Front Bank P1317 Spark Plug Voltage Detection Circuit Malfunction, Rear Bank P1318 Spark Plug Voltage Detection Module Reset Circuit Malfunction, Front Bank P1319 Spark Plug Voltage Detection Module Reset Circuit Malfunction, Rear Bank P1324 Knock Sensor Power Source Circuit Low Voltage P1336 CKP Sensor B Range/Performance P1337 CKP Sensor B Low Input P1359 CKP/TDC Sensor Circuit Connector Disconnection P1361 TDC Sensor Intermittent Interruption P1362 TDC 1 Sensor No Signal P1366 TDC 2 Sensor Intermittent P1367 TDC 2 Sensor No Signal P1381 CYP Sensor A Intermittent Interruption P1382 CYP Sensor A No Signal P1386 CYP Sensor B Intermittent Interruption P1387 CYP Sensor B No Signal P1456 Evaporative Emission Control System Leak Detected (Fuel Tank System) P1457 Evaporative Emission Control System Leak Detected (Control Canister System) P1459 EVAP Purge Flow Switch Malfunction P1491 EGR Valve Lift Insufficient Detected P1498 EGR Valve Lift Sensor High Voltage P1508 IAC Valve Circuit Failure P1519 IAC Valve Circuit Failure P1607 ECM Internal Circuit Failure A P1608 ECM Internal Circuit Failure B P1655 TMA or TMB Signal Line Fault P1656 Automatic Transmission System Malfunction P1660 A/T FI Data Line Failure P1671 A/T FI Data Line No Signal P1672 A/T FI Data Line Failure P1676 Traction Control System FI Data Line No Signal P1677 Traction Control System FI Data Line Failure P1678 FPTDR Signal Line Failure P1681 A/T FI Signal A Low Input P1682 A/T FI Signal A High Input P1686 A/T FI Signal B Low Input P1687 A/T FI Signal B High Input P1690 Traction Control System STB Line Failure P1696 Traction Control Fuel Cut Signal Low Input P1697 Traction Control Fuel Cut Signal High Input P1705 TCM A/T Gear Position Switch Circuit Shorted P1706 TCM A/T Gear Position Switch Circuit Open P1753 TCM A/T Lockup Solenoid Valve "A" Fault P1758 TCM A/T Lockup Solenoid Valve "B" Fault P1790 TCM A/T TP Sensor Circuit Fault P1791 TCM A/T Vehicle Speed Sensor Circuit Fault P1753 TCM A/T ECT Sensor Circuit Fault P1709, P1738, P1739, P1768, P1773, P1788, P1793 & P1795 Automatic Transmission System Malfunction Got it Here and here Edited August 24, 2009 by DelSolSweetie lastresort576 1 Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted August 24, 2009 Share Posted August 24, 2009 thanks you lol. i dont have the obd2 book and tester yet or is this for obd1? Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted August 24, 2009 Share Posted August 24, 2009 niiice thanks, of course i have google, but this definately makes it convenient Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 24, 2009 Author Share Posted August 24, 2009 (edited) obd2 added at least im pretty sure those are the obd2 codes.. i know obd1 is right at least Edited August 24, 2009 by DelSolSweetie Quote Link to comment Share on other sites More sharing options...
darknezz808 Posted November 14, 2010 Share Posted November 14, 2010 I have a question wen I test mine my check engine light flashes me 10s only with long pauses and my srs air bag indactor flashes da code 92 and 51 which one do I follow Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted November 14, 2010 Author Share Posted November 14, 2010 you count the cel light Quote Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted November 14, 2010 Share Posted November 14, 2010 thanks you lol. i dont have the obd2 book and tester yet or is this for obd1? tester? you dont have a paperclip? I have a question wen I test mine my check engine light flashes me 10s only with long pauses and my srs air bag indactor flashes da code 92 and 51 which one do I follow long CEL flashes are counted as 10 each.. short quick flashes are counted as 1 each Quote Link to comment Share on other sites More sharing options...
kmmmntre Posted December 13, 2021 Share Posted December 13, 2021 Can i use best vacuum cleaner for my car to clean interiors. How to make most of it, if interior is dirty, isn’t a good way to use this? Quote Link to comment Share on other sites More sharing options...
