TheWingnut Posted August 12, 2009 Share Posted August 12, 2009 We have a 95 intergraRS, absolutely no frills, that has just started acting up, over 100,000 miles on her. When we start out from a dead start we get a studder for about a seecond or two then everthing is fine. I am thinking fuel filter but I am not a big wrench turner so I don't know, any ideas? If I left out and details I apologize. Wingnut Quote Link to comment Share on other sites More sharing options...
Rick B. Posted August 12, 2009 Share Posted August 12, 2009 is it an automatic or manual? could be a filter, or dirty injectors, or any number of problems. just go through it with a process of elimination. Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 12, 2009 Author Share Posted August 12, 2009 Auto Quote Link to comment Share on other sites More sharing options...
Rick B. Posted August 12, 2009 Share Posted August 12, 2009 how are you doing on fluids? tranny, oil, ect Quote Link to comment Share on other sites More sharing options...
lceah Posted August 12, 2009 Share Posted August 12, 2009 describe this "studder"...when and how... Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 12, 2009 Author Share Posted August 12, 2009 All fluids are changed and topped off. The studder is just when you start out and push the gas peddle for the first two seconds it's like it wants to go but but the is 4-5 little studders then it goes fine, shifts from one gear to the next without studdering. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted August 12, 2009 Share Posted August 12, 2009 when was the last time you had your spark plugs/wires changed Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 12, 2009 Author Share Posted August 12, 2009 when was the last time you had your spark plugs/wires changed About 6 months ago Quote Link to comment Share on other sites More sharing options...
alex37211 Posted August 12, 2009 Share Posted August 12, 2009 could be a distributor problem or at the very least a rotor button or cap. Have you ever changed the fuel filter? If not, you may as well. That is a possibility also. Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 12, 2009 Author Share Posted August 12, 2009 could be a distributor problem or at the very least a rotor button or cap. Have you ever changed the fuel filter? If not, you may as well. That is a possibility also. Whats all involved with the fuel filter change? Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted August 13, 2009 Share Posted August 13, 2009 (edited) Whats all involved with the fuel filter change? Change the fuel filter to answer your post above... Other then that I would agree with the posts above regarding the distributor and assembly. It could be as stated above or the timing is off slightly, but I would agree with starting with what is posted above regarding cap and rotor. Also, if you are running cheap aftermarket plugs and/or wires I would start by looking at those as a potential source. On top of that there is a potential that you have a vacuum leak which could be as simple as a 1 dollar hose. Do what you can to diagnois it and post back with what you have checked before throwing parts at it. Edited August 13, 2009 by Turtlehead Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 13, 2009 Author Share Posted August 13, 2009 any tips on how to change the fuel filter? What to look out for? After market or Original part? Is the system pressurized? if yes, what to do? I can fill fluids, change the oil, change brake pads, spark plugs and wires but messing with gasoline is something new to me. Any knowledge would be nice. wingnut Quote Link to comment Share on other sites More sharing options...
Intac1991 Posted August 14, 2009 Share Posted August 14, 2009 (edited) disconnect your battery... to relieve the fuel system pressure just take off your gas cap... the fuel filter is on the passenger side of the firewall... all you have to do is disconnect your two fuel lines on your filter... unbolt bracket holding your fuel filter on... remove filter! and reverse order to reinstall it... Edited August 14, 2009 by Intac1991 Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 15, 2009 Share Posted August 15, 2009 When the car is off the fuel system only maintains a minor amount of pressure. You will inevitably spill a little, but no more then a splash or so. Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted August 15, 2009 Share Posted August 15, 2009 disconnect your battery... to relieve the fuel system pressure just take off your gas cap... the fuel filter is on the passenger side of the firewall... all you have to do is disconnect your two fuel lines on your filter... unbolt bracket holding your fuel filter on... remove filter! and reverse order to reinstall it... Make damn good and sure to use the new copper rings included with new filter! Quote Link to comment Share on other sites More sharing options...
TheWingnut Posted August 15, 2009 Author Share Posted August 15, 2009 Thanks everybody, will do. Quote Link to comment Share on other sites More sharing options...
