hiemsnox Posted August 4, 2009 Share Posted August 4, 2009 im going to check my ecu tonight, cause the motor was swapped in the car b4 i bought it... i know my ecu should either be a p72 or a chipped p28 right? whats the easiest way to tell exactly which model it is? Quote Link to comment Share on other sites More sharing options...
rx7turbo287 Posted August 4, 2009 Share Posted August 4, 2009 im going to check my ecu tonight, cause the motor was swapped in the car b4 i bought it... i know my ecu should either be a p72 or a chipped p28 right? whats the easiest way to tell exactly which model it is? the ecu have a sticker on the side, xxxx-p72-xxxx or xxxx-p28-xxxxx Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted August 5, 2009 Author Share Posted August 5, 2009 the ecu have a sticker on the side, xxxx-p72-xxxx or xxxx-p28-xxxxx thanks... exactly what i needed to know Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted August 5, 2009 Author Share Posted August 5, 2009 ok so the car has a stock p28 in it WTF.... so now i have a few questions if the car seems to run fine with the p28 in it should i stop driving it short drives? what kind of problems might i see from running the wrong ECU? i prefer hondata but it is also kinda pricey, is there a cheap way of getting say hondata s100? or is there another chip/software that i can get that i can tune the ecu to run like a DOHC should i plan on re-turboing that car next spring so i will need tuning abilities, i just want to see if there is any "cheaper" way of doing it, like used or something sorry bout all the questions but these seem to be hard ones to find answers for Quote Link to comment Share on other sites More sharing options...
