DelSolFreak Posted July 31, 2009 Share Posted July 31, 2009 my windows roll down perfectly fine, but when i roll them up they start out fine then slow down round the mid then rolls up fine again. but i did notice that the window is going up crooked but down normally. any suggestions? Link to comment Share on other sites More sharing options...
airjordan223 Posted July 31, 2009 Share Posted July 31, 2009 take your door panel off and look at the window track it might be a little messed up Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 1, 2009 Share Posted August 1, 2009 mine does it too because they didnt put it in right and i need to pull the door panel off Link to comment Share on other sites More sharing options...
DelSolFreak Posted August 1, 2009 Author Share Posted August 1, 2009 well see i have already pulled the panels off and everything looks ok... i lubed all the rails which help very little.. i think im gonna look for a diagram and see if i can figure out possible issues from it.. or just pull everythink out of the door and inspect it all Link to comment Share on other sites More sharing options...
airjordan223 Posted August 1, 2009 Share Posted August 1, 2009 are both driver and passenger windows doing this or is it just one? Link to comment Share on other sites More sharing options...
DelSolFreak Posted August 1, 2009 Author Share Posted August 1, 2009 both... and the act exactly the same Link to comment Share on other sites More sharing options...
airjordan223 Posted August 1, 2009 Share Posted August 1, 2009 hmmm well its probably not the tracks being off if they are both doing it. well that would be a really crazy coincidence if it was. im not too sure on the problem, but i would say check the wiring for the motors, maybe the ground is off a little? Link to comment Share on other sites More sharing options...
DelSolFreak Posted August 3, 2009 Author Share Posted August 3, 2009 well... i found out that the battery was a little low on water so i threw in some distilled water and it help alot.. i no longer have to pull on the windows to get them up... but they are still going up crooked... i tried adjusting the rails... but that didnt help any Link to comment Share on other sites More sharing options...
airjordan223 Posted August 3, 2009 Share Posted August 3, 2009 is there any difference when you have the car on as opposed to on acc mode? Link to comment Share on other sites More sharing options...
nobody Posted August 12, 2009 Share Posted August 12, 2009 hold em up batteries have water? lol u live u learn Link to comment Share on other sites More sharing options...
Orca89 Posted August 12, 2009 Share Posted August 12, 2009 hold em up batteries have water? lol u live u learn Lead batteries (most, if not all car batteries) have water in them. For the most part nowadays, they're sealed and you don't have to worry about it. Link to comment Share on other sites More sharing options...
JesseCuster Posted August 20, 2009 Share Posted August 20, 2009 my driver side window goes up a bit to far havent looked into it yet though and it also does the slow down thing in the middle Link to comment Share on other sites More sharing options...
Mitchness Posted August 20, 2009 Share Posted August 20, 2009 My drivers side window rose/lowered exactly as you are describing (not the speed problem, but the angle problem). Turned out that the rear adjustment (behind the panel, halfway down the door) was too low. If your window is also going up too high then your stop adjustment needs to be changed. Link to comment Share on other sites More sharing options...
JesseCuster Posted August 20, 2009 Share Posted August 20, 2009 hey thanks Link to comment Share on other sites More sharing options...
