no fuel need help asap please
shanehonda
Posted
okay so I just swapped in a h22 in my 93 si but im getting no fuel to the rail please help I want to start it!!
could be your fuel relay or a bad pump or a fuse could of blowin or you didnt hook the f/i up right so its not reading "GIVE SOME FCKN FUEL B!TCH"...
Posted
what harness? what ecu? what changes to the harness? was anything wrong with the car before the swap?
Posted
where is the fi??? And I used the h23 harness with the p13 ecu just going to wire up vtec but you dont need that to start it ya know and I have a 94 four door I swapped the d16z6 with the p28 and same thing and I replaced th main relay still nothing so its kind of odd how both are doing the same thing??
