Ketnity151 Posted July 16, 2009 Share Posted July 16, 2009 how do i take the leak cover and rotor off my distributor? i need to check the ignition coil and igniter unit.. and the book says to take off the leak cover and rotor to get to em, but i cant take the rotor off without takin off the leak cover, and cant take the leak cover off without taking off the rotor... its seriously pissing me off and i just want to throw the damn thing at a brick wall.. its off a D16Z6 engine Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 19, 2009 Share Posted July 19, 2009 rotor button on that motor sucks balls you have to take off the dizzy cover then rotate the motor by hand until you see the screw that you have to unscrew... you should see an opening in the black cover and the screw will show up in there... kinda hard to explain so i hope you can figure it out Link to comment Share on other sites More sharing options...
Ketnity151 Posted July 20, 2009 Author Share Posted July 20, 2009 yeah.. the screw was lost long ago, so it hasnt even been there, so, i tried and tried pullin it, but it just dont want to pull out Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 20, 2009 Share Posted July 20, 2009 if we are talking about the same rotor button the only thing that would be holding it on is the screw Link to comment Share on other sites More sharing options...
drewkuch Posted July 22, 2009 Share Posted July 22, 2009 might be easier just taking the 3 bolts off the distributor mounts and taking things apart that way. Just dont touch your engine timing if you do it this way. Link to comment Share on other sites More sharing options...
