TrnsDoctr'sSol Posted July 23, 2009 Author Share Posted July 23, 2009 SOOOO... im thinkin bout building the motor before i put it in the sol and i thought i get some advice for parts and sites. Link to comment Share on other sites More sharing options...
Humphries Posted July 23, 2009 Share Posted July 23, 2009 needed for install: custom mounts (hasport, avid, etc.) ECU linkage Wiring harness Engine Transmission the motor only weighs about 40-50 lbs more than the single cam but some say they notice major understeer. a stiffer front spring setup would fix that or just a carbon fiber hood should offset the weight. The shift linkage is different than the D and B series so you'll need to cut the hole at the shifter to fit the new linkage. just a few tips. Link to comment Share on other sites More sharing options...
TrnsDoctr'sSol Posted July 23, 2009 Author Share Posted July 23, 2009 yeah i got just about all that but im not 100% sure but i think the shift linkage is caables or something?? how would that work lol? Link to comment Share on other sites More sharing options...
TrnsDoctr'sSol Posted July 24, 2009 Author Share Posted July 24, 2009 ugghhh.... i need to talk to someone who has done this b4!!!!! FML XP Link to comment Share on other sites More sharing options...
delsolb20vtec Posted July 26, 2009 Share Posted July 26, 2009 actually u may not think u need to swap out the axles or motor mount but the h22 has a commmon problem of snapping axles like nothing hasport has axles that actually do a good job of not breaking and as for wiring for vtec if u allready have vtec all u have to do is cut the ecu connectors when u chanhge the ecu and thats it except for a bunch of other little ones u should also think of upgrading to a prelude radiator u might have to persuade it to fit in it but u can use a slim fit fan to either pull or push air into the engine its not a hard swap to do i go to aai in arizona so if u need anything just hit me up in my email i can wlk u through a swap a engine rebuild or even a manuel to auto conversion or any other questions rodneymullenrules14@yahoo.com Link to comment Share on other sites More sharing options...
Orca89 Posted July 27, 2009 Share Posted July 27, 2009 wow thats almost as good as my dads durango which is 400 somethin to the tank For those interested, I did a little experiment and ran my Sol 'til she starved, and the usable fuel capacity of the Sol is about 11.35 gallons. Link to comment Share on other sites More sharing options...
hondaman08 Posted November 17, 2009 Share Posted November 17, 2009 what exacly is a wiring harness? WHAT?!?!?!?! Link to comment Share on other sites More sharing options...
