integrab18turbo Posted July 13, 2009 Share Posted July 13, 2009 I got a manual integra ls with 180k on clock, now im gonna rebuild it : Type R Piston compression ratio of 11.57:1 + which rod ???? Vision asjustable cam gears Skunk 2 intake manifold OBX Cams Camshafts Type R racing timming belt Skunk2 Valve spring set kit 1000cc Injector T70 or T76 Turbocharger ??? 3.5'' intercooler piping kit 38mm gatewaster,blow off valve, turbo controler Golden Eagle Fuel rail Racing clutch 219mm 330 ft/lbs 6 puck stage 3 clutch those are cost nearly $3k and i do not know what should be changed to make it better, anyways doesnt know how much horsepower it can make ? some one help me ?? hope making around 500hp. Quote Link to comment Share on other sites More sharing options...
DwiZZy Posted July 25, 2009 Share Posted July 25, 2009 I got a manual integra ls with 180k on clock, now im gonna rebuild it : Type R Piston compression ratio of 11.57:1 + which rod ??? ? Vision asjustable cam gears Skunk 2 intake manifold OBX Cams Camshafts Type R racing timming belt Skunk2 Valve spring set kit 1000cc Injector T70 or T76 Turbocharger ??? 3.5'' intercooler piping kit 38mm gatewaster,blow off valve, turbo controler Golden Eagle Fuel rail Racing clutch 219mm 330 ft/lbs 6 puck stage 3 clutch those are cost nearly $3k and i do not know what should be changed to make it better, anyways doesnt know how much horsepower it can make ? some one help me ?? hope making around 500hp. kind of a high compression number... what Valves are you using Quote Link to comment Share on other sites More sharing options...
