prelude98 Posted July 10, 2009 Posted July 10, 2009 I have a 98 prelude. I need to check the the timing belt and valve, but there is one stubborn bolt that will not come out. It will turn to open and that about it. Just won't come out. Seem as if it is strip for the inside. The bolt that i'm talking about is the first one from the header side and by the belt side. If i remember right this is the long one. Not just a nut but a bolt. Need some help, input, advice, whatever you got for me.... Thanks..
xxhrdcr4lifexx Posted July 12, 2009 Posted July 12, 2009 check your post in the general discussion's, i put a solid idea that you should try 1st
airjordan223 Posted July 17, 2009 Posted July 17, 2009 so this bolt only turns part of the way then gets stuck? or you can unscrew it all the way but then it wont come out? have you tried using wd-40 or some kind of anti-seize?
tallhamer88 Posted July 18, 2009 Posted July 18, 2009 Good Luck with getting the bolt out. Like Jordan Said try Wd-40 or some Lub
