HONDA CRX 88 SI Posted July 9, 2009 Share Posted July 9, 2009 Damn i am rebuilding my friends d16a6 and i got the color codes for the rod bearings and took them to honda but when i installed the bearinds the rods are to loose infact i can move them side to side with my hand is that normal or do i need to get different bearings from honda thicker ones. Link to comment Share on other sites More sharing options...
Ketnity151 Posted July 11, 2009 Share Posted July 11, 2009 well that depends on how much side to side movement there is.. theres supposed to be a small tolerance of end play on the rods.. .006 - .012 of an inch from what the book says Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted July 11, 2009 Author Share Posted July 11, 2009 i know but this was to damn loose but i already got the new bearings and there perfect Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted July 17, 2009 Author Share Posted July 17, 2009 Dang theres something i notice today on this when i installed the rod bearings then turn the crank i found out that the compression stroke, hella leaks air when i turn it on the compression stroke and made sure the valves where close. It sounded as if the air was escaping rapidly and it bearly even got hard to turn over could this be bad piston rings or could this be also a bad head gasket or is it normal cause i am just turning it slow. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 19, 2009 Share Posted July 19, 2009 even turning it slow it would get stiffer check your compression rings maybe Link to comment Share on other sites More sharing options...
