kbradio Posted July 7, 2009 Share Posted July 7, 2009 The dashboard and all exterior lights just start flashing and the horn does short blasts while not running and when driving along. Disconnected the battery for 5 mins and reconnected and the same thing happens. Any ideas would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
lceah Posted July 7, 2009 Share Posted July 7, 2009 It's probably a short somewhere... Or, did you change your key or something? Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted July 7, 2009 Share Posted July 7, 2009 It's probably a short somewhere... Or, did you change your key or something? i dont think changing the key would rly have anything to do with this but its possible so im not disagreeing with you iceah just never rly herd of that b4, but i do agree with the shorting out, i would do a thural wire check running to your fuse boxes and to the battery get a manuel to hlp you find the wires alot faster. also you might want to check the fuses while your doin that Quote Link to comment Share on other sites More sharing options...
Kastigir Posted July 7, 2009 Share Posted July 7, 2009 Sounds like the alarm is going off. Quote Link to comment Share on other sites More sharing options...
kbradio Posted July 7, 2009 Author Share Posted July 7, 2009 Sounds like the alarm is going off. Will the alarm go off with the car running? Thanks for the replies! Quote Link to comment Share on other sites More sharing options...
Kastigir Posted July 8, 2009 Share Posted July 8, 2009 Will the alarm go off with the car running? Thanks for the replies! If something is wrong with, sure. Quote Link to comment Share on other sites More sharing options...
kbradio Posted July 8, 2009 Author Share Posted July 8, 2009 If something is wrong with, sure. Left the battery disconnected for 14 hours reconnected and no more problems. Thanks again for all the HELP! Quote Link to comment Share on other sites More sharing options...
lceah Posted July 9, 2009 Share Posted July 9, 2009 Good thing it worked out And yes, changing the key does make a difference because if it's not the right code, the car thinks its key lock is being picked... Quote Link to comment Share on other sites More sharing options...
