different kinds of smoke for different problems
Posted
ok ive been searching on the forum and havent been able to find anything about what color of smoke means what. i was just wondering because im looking at a b16a2 and the owner says it is giving off black smoke. heres what i know so far about th colors..
White-?
Blue-bad rings/headgasket
black-?
brown-oil making its way into the exhaust?
so if anyone else knows what kind of smoke means what then we could fill this in and maybe make a sticky :)
thanks guys and gals!
Posted
white is often coolant
blue is burning oil
black is generally from running rich (too much fuel)
A little bit of white is pretty normal for most honda's if the weather is cool at all.
Posted
blue is burning oil
ah i see. so running rich really isnt THAT bad if i can get it fixed quick. how would i go about fixing the running rich? tune?
Posted
tune, bad sensors, or reset ecu. i see lots of people with i/h/e running rich, i'm assuming this is because the didn't reset the ecu and give it a chance to learn the airflow characteristics.
