hiemsnox Posted June 29, 2009 Share Posted June 29, 2009 ok so as i have stated before, i have a 93 del sol si, with a b18c swapped into it with the lsd tranny... my issue was when i was trying to replace the wheel bearing. the wheel bearing that came out of my car does not match ANY sizes that auto stores said it should match along with many other honda cars... they all showed a differant bearing that was too big... so right now im sadly looking at ebay to get whole new spindles and bearings from another del sol/civic my big question is.... will the axle that is in my car now fit with the new bearing that will be coming with the new spindle... cause i dont want to get these new spindles and then not have a axle that can fit in them. i have to get this firgured out soon cause my .... jerk of a neighbor called the cops and reported my car as "abandoned pos" so now i have to have my car moved by friday....yaya so if you anyone knows the measurements and everything off all the pieces that should be down there so i can match everything up right the first time that would be REALLY helpful as always thanks in advance Link to comment Share on other sites More sharing options...
hiemsnox Posted June 30, 2009 Author Share Posted June 30, 2009 ok so as i have stated before, i have a 93 del sol si, with a b18c swapped into it with the lsd tranny... my issue was when i was trying to replace the wheel bearing. the wheel bearing that came out of my car does not match ANY sizes that auto stores said it should match along with many other honda cars... they all showed a differant bearing that was too big... so right now im sadly looking at ebay to get whole new spindles and bearings from another del sol/civic my big question is.... will the axle that is in my car now fit with the new bearing that will be coming with the new spindle... cause i dont want to get these new spindles and then not have a axle that can fit in them. i have to get this firgured out soon cause my .... jerk of a neighbor called the cops and reported my car as "abandoned pos" so now i have to have my car moved by friday....yaya so if you anyone knows the measurements and everything off all the pieces that should be down there so i can match everything up right the first time that would be REALLY helpful as always thanks in advance heck yes i know im replying to my own post... but mystery solved!!!! i was at autozone last night trying out every single possible wheel bearing from honda and acura with the sales dude and we tried a TON and while we were in the shop on the last possible wheel bearing... it almost fit... so i went to my last option and see if the wheel hub is the same fitting on the inside of the wheel bearing on the bearing that SHOULD be for my car and i pull it out and WAM-O its the right bearing all the way around... ends up that the first bearing that i got was the wrong bearing in the right box!!!! so my searching is done now... just gotta get em installed and im on my way!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
