94 accord Air Conditioning..... stumped..
quisp96
Posted
1994 accord, Compressor won't come but it will run by putting 12v to compressor (or giving ground to the compressor relay). I have swapped both relays mounted on the front of the fans (one is the compressor relay) so I am assuming they are both good. Freon level is within range. Tried jumping thermostat connector (didn't kick compressor on) wondering if this means the thermostat is bad? Is there a way to test it? Also how would one go about testing the thermisistor in the blower housing, I understand these fail often. Sorry for all the questions.... I would like to be system matic about my test procedure, but don't have a shop manual for the car, I'm pretty good with a tester though, thanks in advance.
Brian
