reaper75_s Posted June 1, 2009 Share Posted June 1, 2009 okay i got a 93 accord 10th ann i put 17x7.5 on the car but a few months went by and a squel when you turn forms now but the tires or wheels are not rubbing and the brake lamp light is on but all lights are working suggestions or solutions are greatly appreciated Quote Link to comment Share on other sites More sharing options...
OTiS Posted June 1, 2009 Share Posted June 1, 2009 maybe you need new brakes? Quote Link to comment Share on other sites More sharing options...
reaper75_s Posted June 4, 2009 Author Share Posted June 4, 2009 maybe you need new brakes? sorry that not it i just put new brake pads and rotors all the way around and the squel is not when i hit the brakes it is a squel that you hear and you can fell tension pulling on the steering wheel has you turn but if you turn it far enough the squel stops Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 4, 2009 Share Posted June 4, 2009 More likely the power steering pump. The larger tires put more load on the pump. That poor pump is getting up there in age. It may be low on fluid, the belt might be loose or the pump itself is dying. Quote Link to comment Share on other sites More sharing options...
lceah Posted June 4, 2009 Share Posted June 4, 2009 ^I agree! Quote Link to comment Share on other sites More sharing options...
