AsianLady Posted May 27, 2009 Share Posted May 27, 2009 Alrite, so officially, I don't know which motor to be picking, because its a hard choice. Which one is better? Ls or GSR? I rather have a LS because you can always build it up and a GSR price is a bit too much. Put your inputs for me =] Quote Link to comment Share on other sites More sharing options...
Rick B. Posted May 27, 2009 Share Posted May 27, 2009 an ls will cost more in the long run if you end up building it. a gsr will cost more in the beginning, but the power is there and you really dont have to build much. i say gsr, but then again, im biased. Quote Link to comment Share on other sites More sharing options...
AsianLady Posted May 27, 2009 Author Share Posted May 27, 2009 Yeah, but at the same time I like the LS/VTEC because you can always do your own componts but the GSR... HRM.... both is a hard choice... Quote Link to comment Share on other sites More sharing options...
CRG7 Posted May 27, 2009 Share Posted May 27, 2009 (edited) which civic? Edited May 27, 2009 by CRG7 Quote Link to comment Share on other sites More sharing options...
alex37211 Posted May 27, 2009 Share Posted May 27, 2009 There is a LOT more involved in an LSVTEC setup than just putting a vtec head onto an ls block. Read into the proper method. Without doing it properly, the reliability will not be there. Ive heard of a whole lot of lsvtec setups that have failed. If you are patient enough, you can find a deal on a gsr swap. I'm selling an entire swap with ecu, linkage, etc for $2k. Quote Link to comment Share on other sites More sharing options...
AsianLady Posted May 27, 2009 Author Share Posted May 27, 2009 which civic? Yeah, i know there been a few Ls vtec that runs for a bit than fail. Quote Link to comment Share on other sites More sharing options...
AsianLady Posted May 27, 2009 Author Share Posted May 27, 2009 which civic? Just the usual typical civic. lol Quote Link to comment Share on other sites More sharing options...
Rick B. Posted May 27, 2009 Share Posted May 27, 2009 There is no typical civic. What year and trim? (ex, dx, ect) Quote Link to comment Share on other sites More sharing options...
bluebyu Posted May 27, 2009 Share Posted May 27, 2009 GSR My opinion. take it or leave it. Quote Link to comment Share on other sites More sharing options...
AsianLady Posted May 28, 2009 Author Share Posted May 28, 2009 There is no typical civic. What year and trim? (ex, dx, ect) Hahaha, I guess so. Civic LS, 95 GSR My opinion. take it or leave it. But there problem. Where to find one, lol Quote Link to comment Share on other sites More sharing options...
C92hatchX Posted May 28, 2009 Share Posted May 28, 2009 look on the internet for one...passwordJDM.com Hmotorsonline.com Quote Link to comment Share on other sites More sharing options...
EFHatchTuner Posted June 3, 2009 Share Posted June 3, 2009 There is a LOT more involved in an LSVTEC setup than just putting a vtec head onto an ls block. Read into the proper method. Without doing it properly, the reliability will not be there. Ive heard of a whole lot of lsvtec setups that have failed. If you are patient enough, you can find a deal on a gsr swap. I'm selling an entire swap with ecu, linkage, etc for $2k. Couldnt agree more. Sweet price btw. Id def go with a GSR. I have one with full exhaust and its very fun and extremely reliable as well. If you want boost for cheep id probly go with the ls. Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted June 3, 2009 Share Posted June 3, 2009 (edited) I don't know the price difference between the two complete swaps, but here's my take. Go with the LS. Use the money you save toward boosting the LS (can be done for about 1500-2000 if you piece stuff together yourself). A boosted Stock LS motor can make between 250-300whp (dependent on the tune). A stock GSR isn't going to make much more than that boosted and probably less torque. If you are building both and shooting for high numbers then take the GSR as it flows better and will hit higher numbers. For a stock boosted setup (if you wanted that) an LS would be my choice as it wouldn't cost a ton more than a straight GSR swap. Although, depending on what trim you have I'd choice neither. If you have a civic with something like a D16z6 then you should just build the z6 with forged rods, vitara 75mm pistons, and ACL race bearings (all can be had for about $600) then spend $2000 on a turbo setup and you'd have a reliable 350whp for $2500 and a motor that can be replaced for $500 if the need ever arises. Edited June 3, 2009 by CleanGSR Quote Link to comment Share on other sites More sharing options...
