Kimnchris07 Posted January 20, 2009 Share Posted January 20, 2009 I have a 1992 Civic LX :help: it is a hydraulic manual transmission but i put it in 1st gear to drive and as soon as i started to pull off it seemed as if it slipped out of gear. It did not move but yet the RPM's and Speedometer moved as if i was driving. But also it has a whinding noise as if it is spinning but not catching. IT WILL NOT MOVE IN ANY GEAR. We just replaced the tranny about 3 months ago. But yet the same thing has happend as the last. Any advice or ideas? PLEASE HELP! :help: Link to comment Share on other sites More sharing options...
..SSR.. Posted January 20, 2009 Share Posted January 20, 2009 Clutch is gone. CSB has walked out causing 1st to pop out. 1st synchro spring is worn causing 1st to pop out. One of those 3. Link to comment Share on other sites More sharing options...
Kimnchris07 Posted January 20, 2009 Author Share Posted January 20, 2009 Clutch is gone. CSB has walked out causing 1st to pop out. 1st synchro spring is worn causing 1st to pop out. One of those 3. Could it be just the clutch because it makes the whinding noise in every gear. you can put it in every gear and it still doesnt move but the clutch pedal still feels the same. Sorry wasnt very specific Link to comment Share on other sites More sharing options...
wannaBstuntin Posted January 20, 2009 Share Posted January 20, 2009 pre-op or post-op? Link to comment Share on other sites More sharing options...
Kimnchris07 Posted January 20, 2009 Author Share Posted January 20, 2009 pre-op or post-op? What do you mean? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 20, 2009 Share Posted January 20, 2009 Put it in 5th, bounce it off the limiter and dump the clutch. If it stalls, the clutch is fine. Link to comment Share on other sites More sharing options...
