msand9898 Posted January 17, 2009 Share Posted January 17, 2009 My 1993 Accord EX recently developed foamy airbubbles in the Power Steering Reservoir? I fill it up and when I cap off the reservoir it overflows with even more foamy bubbles? Any help is appreciated... Link to comment Share on other sites More sharing options...
James Matteu Posted January 17, 2009 Share Posted January 17, 2009 You have a leak. This is not a leak where fluid comes out, this is a leak where air gets in. Make a visual inspection of your entire system and find the leak. Link to comment Share on other sites More sharing options...
Turtlehead Posted January 17, 2009 Share Posted January 17, 2009 ^Yes. You have a leak. Most likely (99%) your steering rack is leaking. Link to comment Share on other sites More sharing options...
ady5179 Posted March 13, 2009 Share Posted March 13, 2009 I was also have same problem. Another problem is, when I turn the steering the RPM drop Link to comment Share on other sites More sharing options...
alex37211 Posted March 13, 2009 Share Posted March 13, 2009 I was also have same problem. Another problem is, when I turn the steering the RPM drop That's why it's called "power" steering. There's a pulley on the p.s. pump that spins under power of your engine. When you turn the wheel, the pump is put under pressure and requires more power from the engine. Thus the rpms will drop. Link to comment Share on other sites More sharing options...
Pballer2005 Posted March 13, 2009 Share Posted March 13, 2009 I was also have same problem. Another problem is, when I turn the steering the RPM drop and the fact that you have a leak means that the pump is compressing/expanding air in the system, while the fluid in the pump wont compress/expand so its having to do more work. Link to comment Share on other sites More sharing options...
