19blade64 Posted January 13, 2009 Share Posted January 13, 2009 i did not start my car for a month because of snow so today i try and no go so i try some starting fluid no go so i pull a plug and turn it over no spark i checked the rotor and it turns but dont know if i can check coil or the module thanks greg Link to comment Share on other sites More sharing options...
lceah Posted January 21, 2009 Share Posted January 21, 2009 lights turn on? Link to comment Share on other sites More sharing options...
93d3ls0l Posted February 25, 2009 Share Posted February 25, 2009 i did not start my car for a month because of snow so today i try and no go so i try some starting fluid no go so i pull a plug and turn it over no spark i checked the rotor and it turns but dont know if i can check coil or the module thanks greg just a lil advice maybe you should be a lil more descriptive. as far as your problem goes im going to assume it turns over, (hints the starting fluid) this is what i would do,take the coil wire off the rotor cap and see if your getting spark from the coil if so look at the rotor cap and button to see if there are any noticeable burn marks. as to they may need replacing.if no spark from the coil check if you are getting power to the coil. if so replace coil and go from there. Link to comment Share on other sites More sharing options...
