94 del sol window removal
CelticRacer
Yes.
lower the window
remove all bolts, all around the edges of the black panel and a few in the middle which hold the motor and such.
pull hard. The black panel is glued so you need to pull quite hard to get it off. Do your best not to bend it, even if you do it will be fine when you bolt it back up.
Yes.
lower the window
so in the interior of the car you pull the back tray boxs etc. off by the rear speakers?
yea, you need to pull speaker panels, rear center panel, and your compartments. That should cover it though.
What happen, motor die? Window break?
tinting it...
is putting it back in tyhe opposite process?
  • 2 months later...
sorry to revive a dead thread but i figured it was better then starting a new one.
Question: Does anyone know how to remove the two front corner windows on a del sol?
i talked to my guy at honda and he couldnt find anything and the manual i have doent even mention them...
brick.jpg I wouldn't go by this advice to be honest, in the teamdelsol guide for clearing the rear window drains out it advises to put new caulk sealant on, and also when I took my rear window out, I sealed it up with sealant, then a small amount of water still came through (we tested it the next day with a hosepipe on the car), so I used silicone sealant again around the edges to make sure it was 100% water tight.
Thanks seb, the rear window is back in and sealed. My question now is the front windows that don't move on each of the doors. I can't find anything online about removing them
Tried it once already and fracked up a piece of tint film in the process.I read that for the teg you have to cut out the rear one that's like the one on the sol but I know there has to be a better way
I would have agread with you months ago, but after doing it on an accord and now a del sol its really not that difficult. Oh, I would have considered going to a shop but they wouldn't do 2.5 light vis tint on any car that's not a limo
Obviously, because that's darker than the law allows. Be funny when you get pulled over and have to have it removed.
be even funnier when they look at the "its legal cuz of poor vision in bright light sticker" given to me by an eye dr. and they cant do crap bout it :thumbsup:
That and they have to test it with a light meter, which most cops aren't going to be carrying around with them.
here is a pic of the tint i have on now and the triangle window that is being a pain in my ass
and yes i have heard everything anyone cold ever say about the tint being illegal, so save your time if thats what your reply is going to be.
you need to paint the car now cause the tint is 100x darker lol
oh and almost forgot i just saw the same question on d-series.org (was it you??) but anyway they said a hammer or do it while its on the car
lol, i know. its like a matte black damn near.
yep, i r on der' too
Here is a write up on howto remove the front corner windows that no one seems to have except a mechanic at the dealership...
1. remove the interior door panel
2. peel back the plastic water cover
3. remove the main window by removing the mounting bolts at the bottom of the door and pull the glass out. see image below
4. remove the window seal, run channel, and glass guide. see image below
5. remove the front corner glass as shown in the image below.
6. To re-install reverse the procedure.
