Hondadawg Posted January 10, 2009 Share Posted January 10, 2009 I have a 1994 Honda Civic 5-speed transmission and I am having trouble shifting gears. I started to have trouble with 1st gear only, but now am having trouble getting in/out of all the gears. I have not done any modifications to this car and is has run well over the years. What is happening and how do I fix it? Link to comment Share on other sites More sharing options...
alex37211 Posted January 10, 2009 Share Posted January 10, 2009 A start would be to change the fluid. Drain that old stuff out and fill it with 10-30 motor oil. If that doesn't make it better, check your slave cylinder and change the fluid in your master cylinder / clutch system. If that doesn't work, buy another tranny. Like $150 for a good one. (i'm selling one right now) Link to comment Share on other sites More sharing options...
..SSR.. Posted January 12, 2009 Share Posted January 12, 2009 Master or slave are going out, clutch probably is too. Link to comment Share on other sites More sharing options...
PITBULL111584 Posted January 19, 2009 Share Posted January 19, 2009 If is not the slave or master you have a 1&2 gear fork broken they are really easy to fix but if you dont have the knowledge just buy a new one in the junkyar for like &75 Link to comment Share on other sites More sharing options...
..SSR.. Posted January 20, 2009 Share Posted January 20, 2009 Broken fork doesn't stop it from going in gear. Just harder to get into gear. Broken 1st fork doesn't affect other gears. Link to comment Share on other sites More sharing options...
quake Posted January 20, 2009 Share Posted January 20, 2009 A start would be to change the fluid. Drain that old stuff out and fill it with 10-30 motor oil. If that doesn't make it better, check your slave cylinder and change the fluid in your master cylinder / clutch system. If that doesn't work, buy another tranny. Like $150 for a good one. (i'm selling one right now) When I had this problem........luckily it was just that it was in need of new fluid.....and that could very well be the reason for you too.........although i've never heard of filling it with motor oil....i'm sure it would work though.........anyway....if you change the fluid in your master cylinder....it's a bitch to get all the air back out of it......I learned that the hard way.....so...just a tip......fill it from the bottom up...gets all the small air bubbles out....go to an auto parts store and get a small oil can....you know...the one with the pump handle on it....and attach it to the bottom of the clutch line..... Link to comment Share on other sites More sharing options...
