alright guys i have 94 civic hatch and im putting an h22 in it i went to go and start it but didnt here the fuel pump kick and their is no spark also, now i can tap over the wires for the fuel pump and their is power to so i replaced the relay with a new 1 and still the same problem i broke the tps sensor it has been replced and due to natural ware and tare the knock sensor had got dameage to it also, iam at a lose if any one can help it would be great
It's more than likely an ignition problem. Check to make sure all of your fuses are good, then check for spark. If all fuses are good and no spark then your distributor might be bad, or wired wrong.
fuses are all good when i check the distrubtor i can hear the pump relay kick so im think that it could be that but not to sure is their a way to check the coil or any thing like that
alright i found out what the problem was i had a bad external coil, replaced it with a friends and all of the secondary systems cam on the car runs but i have a leaky fuel line have to wait until the parts store open on monday to get what i need and it on from their
