..SSR.. Posted December 23, 2008 Share Posted December 23, 2008 Not really. This little punk just went out to Redwood CA for a turbo road race Y8 6th gen. MFactory 3.083 1st MFactory 4.7 FD Quaife LSD Needed a ton of work. Started out as a core trans. Link to comment Share on other sites More sharing options...
Xeryon Posted December 23, 2008 Share Posted December 23, 2008 how do you test each product you build? Or do you assemble and pray? Link to comment Share on other sites More sharing options...
..SSR.. Posted December 23, 2008 Author Share Posted December 23, 2008 Bench shift and spin MS in each gear. As far as testing for grinds that isn't needed due to the inspection of parts and clearance checking. I am working on a "dyno" for kicks though. Won't measure power, just let me shift it with power going through and a load on it. Will make R&D a lot easier than constantly dropping the trans from the car. Link to comment Share on other sites More sharing options...
Repsol Posted January 3, 2009 Share Posted January 3, 2009 Out of curiosity, is it hard to swap casings? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 15, 2009 Author Share Posted January 15, 2009 For me no. I'm assuming you didn't reshim the mainshaft when you did yours. If so, expect it to not last more than 50k. Less depending how far off the shim is. Link to comment Share on other sites More sharing options...
Repsol Posted January 15, 2009 Share Posted January 15, 2009 We haven't swapped them yet. How exactly do you go about doing that? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 16, 2009 Author Share Posted January 16, 2009 Go by the Helms manual. Not how I do it now, but its how I did it the first time. Link to comment Share on other sites More sharing options...
Repsol Posted January 16, 2009 Share Posted January 16, 2009 I have a Chiltons, or go with Helms? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 16, 2009 Author Share Posted January 16, 2009 Helms Link to comment Share on other sites More sharing options...
