Xavier Posted December 21, 2008 Share Posted December 21, 2008 i have a 97 ex coupe and am planning on swapping in the rear disc brakes off a 97 integra do i need to change the proportioning valve??? If so, will the 2000 civic si valve work???? Quote Link to comment Share on other sites More sharing options...
Xeryon Posted December 21, 2008 Share Posted December 21, 2008 If you are using Integra swap parts use the Integra MC, booster and proportioning valve. If you are using SI swap parts the MC, booster and proportioning valve should not need to be replaced. SI brakes are a hair smaller and your originals should work fine. Quote Link to comment Share on other sites More sharing options...
Xavier Posted December 26, 2008 Author Share Posted December 26, 2008 If you are using Integra swap parts use the Integra MC, booster and proportioning valve. If you are using SI swap parts the MC, booster and proportioning valve should not need to be replaced. SI brakes are a hair smaller and your originals should work fine. i was told that it was not necessary to change the master cylinder on my civic, that the only thing that needed to be changed was the propotioning valve!!!???? Quote Link to comment Share on other sites More sharing options...
Xeryon Posted December 26, 2008 Share Posted December 26, 2008 If you are using Integra swap parts use the Integra MC, booster and proportioning valve. If you are using SI swap parts the MC, booster and proportioning valve should not need to be replaced. SI brakes are a hair smaller and your originals should work fine. The answer to your question is already here. Quote Link to comment Share on other sites More sharing options...
