i heart my ek9 Posted December 12, 2008 Share Posted December 12, 2008 well i kinda have a little problem my car shakes between 60 and 80 mph and it stops when i hit 80 what can it be? im kinda stumped on this one any help would be appreciated! Link to comment Share on other sites More sharing options...
lastresort576 Posted December 12, 2008 Share Posted December 12, 2008 wheels out of balance most likely... Link to comment Share on other sites More sharing options...
JDMEkHatchy Posted December 12, 2008 Share Posted December 12, 2008 wheels out of balance most likely... what he said .... also maybe your struts?? idk but my cousins little tercel's struts are bad and they make the car shake quite a bit as well... maybe im wrong im not an expert but im pretty sure im not completely wrong Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 12, 2008 Share Posted December 12, 2008 Need your wheels balanced most likely. If you haven't had an alignment in a while, you might as well get that done too. Link to comment Share on other sites More sharing options...
C92hatchX Posted December 12, 2008 Share Posted December 12, 2008 tie rod? Link to comment Share on other sites More sharing options...
adamEj6 Posted December 12, 2008 Share Posted December 12, 2008 prolly tires outta balance. but what do i know, im just a doctor... Link to comment Share on other sites More sharing options...
i heart my ek9 Posted December 12, 2008 Author Share Posted December 12, 2008 well imma take it to a tire rod and see if i can get them balanced and if thats not the case then whats the next step i should take? Link to comment Share on other sites More sharing options...
adamEj6 Posted December 12, 2008 Share Posted December 12, 2008 youre gonna take em to a tie rod? wtf? tire shop**** haha Link to comment Share on other sites More sharing options...
i heart my ek9 Posted December 12, 2008 Author Share Posted December 12, 2008 hahhaha yea my bad tire shop i was still thinking about the tie rod hahaha Link to comment Share on other sites More sharing options...
JDMEkHatchy Posted December 13, 2008 Share Posted December 13, 2008 i wanna take my car to a tire rod too!!!! lol Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 13, 2008 Share Posted December 13, 2008 well imma take it to a tire rod and see if i can get them balanced and if thats not the case then whats the next step i should take? Let us know if that's not the case, because it most likely is. Link to comment Share on other sites More sharing options...
i heart my ek9 Posted December 13, 2008 Author Share Posted December 13, 2008 for sure ill keep you guys posted! Link to comment Share on other sites More sharing options...
Xeryon Posted December 13, 2008 Share Posted December 13, 2008 keep in mind that a tire shop usually only balances wheels up to about 60-70 mph as that is as fast as the machine goes. Even after a balancing there still might be a shake at 70+ Link to comment Share on other sites More sharing options...
C92hatchX Posted December 13, 2008 Share Posted December 13, 2008 so thats why my wheels shake! Link to comment Share on other sites More sharing options...
Kastigir Posted December 13, 2008 Share Posted December 13, 2008 so thats why my wheels shake! You shouldn't be driving 70+ Link to comment Share on other sites More sharing options...
C92hatchX Posted December 13, 2008 Share Posted December 13, 2008 i usally dont but there are times i want to Link to comment Share on other sites More sharing options...
Kastigir Posted December 13, 2008 Share Posted December 13, 2008 i usally dont but there are times i want to Well of course there are always times we want to. I typically set my cruise 6-9 MPH over the speed limit. In a 65 that means usually 71. My Camry has a real bad shake, that only gets worse as I go faster. I know it's probably bad tires cause I've already blown 2 of them. Your shake *could* be a bad belt in a tire, though I doubt it. Link to comment Share on other sites More sharing options...
i heart my ek9 Posted December 13, 2008 Author Share Posted December 13, 2008 well i mean i just go witht he flow of the traffic but in between is when the shaking starts once it hits 80 its a smooth ride Link to comment Share on other sites More sharing options...
C92hatchX Posted December 13, 2008 Share Posted December 13, 2008 Well of course there are always times we want to. I typically set my cruise 6-9 MPH over the speed limit. In a 65 that means usually 71. My Camry has a real bad shake, that only gets worse as I go faster. I know it's probably bad tires cause I've already blown 2 of them. Your shake *could* be a bad belt in a tire, though I doubt it. well the fronts are bran new and back are fairly new, when i first put them on they rode fine and after ahwile the would shake about 70ish Link to comment Share on other sites More sharing options...
Kastigir Posted December 13, 2008 Share Posted December 13, 2008 well the fronts are bran new and back are fairly new, when i first put them on they rode fine and after ahwile the would shake about 70ish Out of balance due to to wear most likely. Link to comment Share on other sites More sharing options...
i heart my ek9 Posted December 14, 2008 Author Share Posted December 14, 2008 maybe thats probably the case with mine mine are pretty old but i might some new rims on wedsnday but im not sureif thats gonna stop theproblem Link to comment Share on other sites More sharing options...
Ben. Posted December 14, 2008 Share Posted December 14, 2008 Check and make sure rotors aren't warped.. Check tires for knots and bumps..probably things that have already been said. Link to comment Share on other sites More sharing options...
lastresort576 Posted December 14, 2008 Share Posted December 14, 2008 Well of course there are always times we want to. I typically set my cruise 6-9 MPH over the speed limit. In a 65 that means usually 71. My Camry has a real bad shake, that only gets worse as I go faster. I know it's probably bad tires cause I've already blown 2 of them. Your shake *could* be a bad belt in a tire, though I doubt it. lol dude what year camry? my '94 gets a pretty damn good shake at 80'ish and some times really bad at 90...but it depends on the weather as well it seems. Link to comment Share on other sites More sharing options...
Kastigir Posted December 14, 2008 Share Posted December 14, 2008 lol dude what year camry? my '94 gets a pretty damn good shake at 80'ish and some times really bad at 90...but it depends on the weather as well it seems. It's a '94, but I know it's the tires. You can feel the vibration as soon as you start moving. I'm guessing they have retreads on it. Last two tires I lost, each time the car started shaking before they shredded. I really need to get 2 new tires. What sucks is that these have a good amount of tread left. Link to comment Share on other sites More sharing options...
C92hatchX Posted December 14, 2008 Share Posted December 14, 2008 Out of balance due to to wear most likely. what would be making them wear? Link to comment Share on other sites More sharing options...
