1991 Honda accord (EX) KILL SWITCH HELP!
SOHCcivic99
Or splice into the power wire for the fuel pump with a hidden switch.
Cut the power wire going to the fuel pump. Take one side of the cut wire to one side of the switch.....the other side of cut wire to the other side of the switch. Just make sure you hide the switch somewhere nobody will look for it.
what type of guage wire size? (noob question) where is the fuel pump located? first time workin on this type a car
Fuel Pump should be under the back seat. Gauge wire.....match it up to whatever the fuel pump uses. You might go one gauge larger since you'll be running it a good distance to and from the switch.
