Currpt_God Posted December 8, 2008 Share Posted December 8, 2008 so i just bought a 88 crx and the climate contorls were busted so i pulled it out and now i cant find one to put back in.... so does the controls out of a 88 - 91 civic work the same because i can find alot of them o and the crx has AC Link to comment Share on other sites More sharing options...
Kastigir Posted December 8, 2008 Share Posted December 8, 2008 so i just bought a 88 crx and the climate contorls were busted so i pulled it out and now i cant find one to put back in.... so does the controls out of a 88 - 91 civic work the same because i can find alot of them o and the crx has AC It should fit, but I can't say that with any certainty. Link to comment Share on other sites More sharing options...
CRG7 Posted December 8, 2008 Share Posted December 8, 2008 They always crack, so unless it's completely destroyed, put it back in. Link to comment Share on other sites More sharing options...
Joe W Posted December 8, 2008 Share Posted December 8, 2008 Yes you should be able to fit a 88-91 civic control in there. Or you can do a 92-95 control conversion not too hard and doesn't look bad. (Color mismatch) Here is a pic of what it looks like in my car Link to comment Share on other sites More sharing options...
Currpt_God Posted December 8, 2008 Author Share Posted December 8, 2008 ya mines compleatly destroyed .... its in 2 pieces what do you have to do to switch over to the 92 ?? Link to comment Share on other sites More sharing options...
Joe W Posted December 9, 2008 Share Posted December 9, 2008 One of the plugs needs to be rewired, not too difficult all the colors are the same except 2 if I remember correctly, should be able to google it. Then you have to cut one of the brackets for the adjustment cable and relocate it. And then mounting it just requires drilling two holes in the brace (under the stock control), and rigging a bracket to hold up the back. Seriously not near as bad as it may sound, and now I still have full range of hot and cold/fan speed, and all buttons function. But most importantly it won't be as prone to breakage. Link to comment Share on other sites More sharing options...
