zoltron30 Posted December 6, 2008 Share Posted December 6, 2008 where does the transmission fluid go on a 01 honda accord? when i check the fluid levels by removing the stick in the transmission, is that where it goes? Link to comment Share on other sites More sharing options...
Kastigir Posted December 6, 2008 Share Posted December 6, 2008 where does the transmission fluid go on a 01 honda accord? when i check the fluid levels by removing the stick in the transmission, is that where it goes? Yes. Link to comment Share on other sites More sharing options...
Turtlehead Posted December 7, 2008 Share Posted December 7, 2008 Assuming it is a 4 cyl. if it is a V6 you can remove the 17mm head bolt on top of the trany where some models have oil cooler hose assembly and put it in there (provided you do not have the cooler attachment located there), if you do then just go through the dip stick tube. Link to comment Share on other sites More sharing options...
