Problems
I was using an amp ripped from a guitar amplifier, and it worked fine for weeks, then started shorting out. After I redid all the connections a little neater, it started working, then, a few weeks later, it quit working all together, and now just makes a scratchy sound but no music. . .
Here's how it was setup: It was plugged into a power inverter that I have, and getting the sound from a parallel connection with the two back speakers.  The output wires then branch off in two, and then go to the two subs.  I ripped a different amp and it worked, so its not the speakers.  Could it have burned out? Does anyone have any  other ideas. . .?
now you said you had the speakers wired in parallel. assuming theses a 4 ohm car audio speakers, that created a 2 ohm load. then you ran two subs off it also. if the subs were 4 ohm svc subs, then your setup was being run a 1 ohm. the guitar amp is meant to drive an 8 ohm speaker. a 1 ohm load is too much current for that amp. and it fried the amp internally. if you just wired two 4 ohm speakers in series, that would make an 8 ohm load. then your amp should run for a while (but guitar amps arent built to handle vibrations, temperatureextremes, and moisture like a car audio amp).
  • 2 weeks later...
Alright I don't know if anyone knows about this, but I got an amp from a friend who says he burned it out by accidentially crossing some wires he shouldn't have. (He didn't tell me which) He told me I could have it, and upon inspection, I saw a black burn- looking mark on the board between two 3400 ohm resistors. I don't think the finals are burned out, but could a fried resistor cause an amp (600 watt two channel profile) to quit working or act like a blown one? If I can fix this, that's like a 150$ amp for
2$ !
