chris_agu28 Posted November 29, 2008 Share Posted November 29, 2008 Okay I am soon to get a 5 speed tranny in my car so I ditch that stupid 4 speed. But.. The big thing I am going to have a problem is the new tranny is a hydro style clutch but the current one is a cable. So which way do I go about doing this. I wish I could find a si from a cable style crx but that is hard to find around here. I was reading I can convert the pedal assembly and run the lines, reservoir, and slave cylinder. which is suppose to be a lot of custom work. I would have to find those parts too since the donor car I am getting the tranny from is using those parts. OR I go to hasport and buy the cable to hydro adapter but I dunno will fit the d series or does it not matter. I am pretty sure I will swap a new engine in the future so which one will be easier to work with now and in the future. I heard the hydro is a lot harder to do but worth it cause it gives more of a stable feel on the pedal and no worries about the cable snaping but is it worth the trouble? What do you think I should do. Any input would be great. Link to comment Share on other sites More sharing options...
..SSR.. Posted November 29, 2008 Share Posted November 29, 2008 HASport makes a kit for the D. Just use a cable trans. You won't have any problems with the cable, if you do they are cheap to replace with a new one. Link to comment Share on other sites More sharing options...
chris_agu28 Posted November 29, 2008 Author Share Posted November 29, 2008 okay everybody told me to talk to you about the situation and see what you say. I wanna find a si tranny cable style cause the gearing is SO MUCH better. I drove my friends si crx and the tranny is awesome. Awesome I just gotta find out when I can get a adapter from them until I find the desired tranny cause that tranny I have now sucks and 4spd ftl. I hate being at a high rpm at crusing. Now Do I have to have to get a different shift linkage if I use any other d series tranny such as a si tranny? or even the hydro tranny or is that only when doing a engine swap? Link to comment Share on other sites More sharing options...
..SSR.. Posted November 29, 2008 Share Posted November 29, 2008 Go ahead and jump, blow your friends CRX Si away. 6,800 RPM redline, 205/50/15 tires Your 4spd RPM drop top speed 1 - 3.250..........xxxx............44 2 - 1.650..........3436............87 3 - 1.033..........4254............139 4 - .823............5415............175 FD - 3.250 WDR bombtastic cherry pie with soda on the side trans .......................RPM drop top speed 1 - 3.083..........xxxx............37 2 - 1.944..........4251............59 3 - 1.565..........5457............74 4 - 1.250..........5467............92 5 - .702............3817............164 FD - 4.058 Cruising RPMs ..........55mph/70mph/80mph 4spd - 2144 - 2728 - 3118 WDR - 2283 - 2906 - 3321 And here is a visual for you. Green is 4spd, red is WDR bombtastic cherry pie with soda on the side Graph Here is 4spd green vs CRX Si red Graph Link to comment Share on other sites More sharing options...
chris_agu28 Posted December 8, 2008 Author Share Posted December 8, 2008 Well since I am getting a LS motor, I am curious to know what tranny I should use? I kinda wanna stay cable. would a b16 tranny work on a b18 ls? Link to comment Share on other sites More sharing options...
..SSR.. Posted December 8, 2008 Share Posted December 8, 2008 Yep. Be careful when buying a cable trans. Most will have a grind in at least one gear. Link to comment Share on other sites More sharing options...
Joe W Posted December 8, 2008 Share Posted December 8, 2008 Yep. mine grinds second and reverse sometimes. Link to comment Share on other sites More sharing options...
chris_agu28 Posted December 9, 2008 Author Share Posted December 9, 2008 dang that suck :( My friend's si grinds second and sometimes third. It sucks. I will have to search and hope I get lucky. Link to comment Share on other sites More sharing options...
