jkm345 Posted November 28, 2008 Share Posted November 28, 2008 i just recently put a type-r head on my block..after i connected evrything, i turn the car on and it just goes all the way up to 2,500 rpm and just stays there, i dunt understand why it stays up that high..it doesnt drop..i noe that one of my spark plug wire is not good, but can it cause a problem like this??i check my timing its just off by a little bit, meaning it shouldnt even rev that high even if it was off..is there anything i might of forgot??or any suggestion on why?? Link to comment Share on other sites More sharing options...
C92hatchX Posted November 28, 2008 Share Posted November 28, 2008 mine usally idles pretty high when its cold, did you have it on long enough for it to heat up? Link to comment Share on other sites More sharing options...
..SSR.. Posted November 28, 2008 Share Posted November 28, 2008 Did you check all the usual stuff? Link to comment Share on other sites More sharing options...
cranny Posted November 28, 2008 Share Posted November 28, 2008 vacuum leak , or misplaced connections. Link to comment Share on other sites More sharing options...
jkm345 Posted November 28, 2008 Author Share Posted November 28, 2008 yeahs im thinking it could be a vacuum leak..and yes, i left it running until the radiator fan came on!!but i check all the vaccuum connestions and evrything seems to be in place! Link to comment Share on other sites More sharing options...
2gboostedteg Posted November 29, 2008 Share Posted November 29, 2008 it really sounds like a vacume leak of somekind, maybe there is a small intake manifold gasket leak, or the idle screw is set high try turning that down. Link to comment Share on other sites More sharing options...
spoon Posted November 29, 2008 Share Posted November 29, 2008 ummm, did you use the correct p73 ecu? Link to comment Share on other sites More sharing options...
jkm345 Posted December 1, 2008 Author Share Posted December 1, 2008 wells..i have an integra gsr with a chipped p72 ecu..and yes, ur right, i found out i have a vaccum leak, i had a b16 intake manifold but it was obd0 and i was using my gsr throtttle body and somehow those didnt want to connect to the other stuff on it..i forgot wats its called but i found the reason..(dunt ask me why i have a b16 intakemanifold, it was the cheapest thing i could get at the time).. also does anyone noe why my cylinder #1 is not firing...i was thinking it was my distributor, but wen i changed in a new one, the same thing happened, im hoping i just need to change my spark plug wires, just on a note, is there any other things i should look at? Link to comment Share on other sites More sharing options...
Hondahunter Posted December 1, 2008 Share Posted December 1, 2008 wells..i have an integra gsr with a chipped p72 ecu..and yes, ur right, i found out i have a vaccum leak, i had a b16 intake manifold but it was obd0 and i was using my gsr throtttle body and somehow those didnt want to connect to the other stuff on it..i forgot wats its called but i found the reason..(dunt ask me why i have a b16 intakemanifold, it was the cheapest thing i could get at the time).. also does anyone noe why my cylinder #1 is not firing...i was thinking it was my distributor, but wen i changed in a new one, the same thing happened, im hoping i just need to change my spark plug wires, just on a note, is there any other things i should look at? the actual plug, if you haven't already. seems you're working backwards from what i would. maybe i missed something in here though? Link to comment Share on other sites More sharing options...
88prelude Posted December 1, 2008 Share Posted December 1, 2008 you could adjust your throtle cable...and if piston 1 isnt firing it could be plug, wire, distrubutor, or coil(s) Link to comment Share on other sites More sharing options...
jkm345 Posted December 2, 2008 Author Share Posted December 2, 2008 my cable is fine..that was the first thing i checked up on..but im waiting for my spark plug wire to come in since they didnt have any at the auto store i decided to order mine..should be here either this week or next week, soo tempting though, really want to drive the car and see wats the difference between the gsr head n type-r Link to comment Share on other sites More sharing options...
