shak3yb0n3z Posted November 25, 2008 Share Posted November 25, 2008 I've been doing research and haven't found much on the VTEC-E. i recently did some maintenance on my 92 Civic Hatch with a D15Z1 in it. i get some hesisitation between 2500-3500rpms. i think it's the vtec-e kicking in and then back out, cuz after 3500 it drives really good. between 2500-3500 it's almost undrivable. I'm thinking i may have used the wrong weight oil. 20w-50. my reasoning for this was it was an old engine and i thought the thicker oil may help seal things up a bit. I'm guessing wrong and I'm considering draining the oil and throwing 10w-30 or 40 in there and see what happens. i also replaced the spark plugs, rotor and cap. seafoam in the crankcase, vacuum line and gas tank. the car runs good over all except inside that rpm range. I know little about vtec-e and any help is much appreicated as i can't seem to find much on the subject via google. Link to comment Share on other sites More sharing options...
lastresort576 Posted November 25, 2008 Share Posted November 25, 2008 yea thats a common misconception...this is a honda motor not an older domestic. reason being is that the tolerances are alot tighter and 20w50 is completly unessecary and could put excess strain on the cam shaft. you should always run whats recomended in your owners manual...and its winter time right now so put in 5w-20/30 in the spring summer rock some 10w30 or stick to the 5w20/30 w/e. however i doubt thats your issue. is it a recent occurance or always been there? ive never rocked that engine but i would kinda think it could be normal. next time you're on empty and about to fill up, throw some chevron techron fuel inector cleaner in it then fill up and that could help you out some anyways in general. Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted November 25, 2008 Author Share Posted November 25, 2008 recent occurrence. I'm gonna change the oil tomorrow @ school and see if that helps. i wasn't thinking when i put that heavy oil in there. i hate when i don't think crap through. thanks for the quick feedback bro! any others wanna chime in please feel free too Link to comment Share on other sites More sharing options...
mpearce1974 Posted November 25, 2008 Share Posted November 25, 2008 recent occurrence. I'm gonna change the oil tomorrow @ school and see if that helps. i wasn't thinking when i put that heavy oil in there. i hate when i don't think crap through. thanks for the quick feedback bro! any others wanna chime in please feel free too Already did, though you seem to be ignoring me on Aim now! :nono: Link to comment Share on other sites More sharing options...
..SSR.. Posted November 25, 2008 Share Posted November 25, 2008 Unplug the VTEC solenoid... Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted November 25, 2008 Author Share Posted November 25, 2008 Unplug the VTEC solenoid... cool. i figured that would work. wasn't sure if that would throw any engine codes Link to comment Share on other sites More sharing options...
..SSR.. Posted November 25, 2008 Share Posted November 25, 2008 It will. Anything you do to disable it other than modifying or changing the ECU will cause a CEL. Link to comment Share on other sites More sharing options...
C92hatchX Posted December 11, 2008 Share Posted December 11, 2008 mine does the same between 1500-2500 in 2nd gear, but when the VTEC kicks in it runs amazing it feels like it just wants to die or dosnt feel like going Link to comment Share on other sites More sharing options...
..SSR.. Posted December 12, 2008 Share Posted December 12, 2008 Thats because its a 1.5L with crap for flow and one valve open until VTEC kicks in. Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted December 18, 2008 Author Share Posted December 18, 2008 on the VTEC-E wouldn't that be the other way around? wouldn't VTEC kick in to initiate the lean burn(closing one valve half way) and then shut off in higher rpms? i'm confused. on top of that my problem is very very intermittent. there are days where the car runs great throughout my rpm band. and there's times when it bogs in low rpms and runs great after 3000rpms. and get this... when it does bog down, i can turn my car off turn it on like 2 minutes later and the problem goes away. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 18, 2008 Share Posted December 18, 2008 No, VTEC opens the 2nd valve. A/F is not controlled by the valves. You need to troubleshoot your problem when it happens again. Link to comment Share on other sites More sharing options...
hondacbrboy00 Posted December 24, 2008 Share Posted December 24, 2008 add a little bit of oil, you may have a small oil leak, i have the same engine, hate but have to deal with it. it does that to mine as well. i do have an oil leak, and when i add a little oil, problem is gone. and runs fine. Link to comment Share on other sites More sharing options...
