scornell Posted November 24, 2008 Share Posted November 24, 2008 All, I attempted to install a back up camera in our new 2008 Honda Odessey this weekend. I had to run the camera's power wire to the back up lights, splicing into the van's back up lights wires. (In years past, I've installed car stereo's, amps, etc many many times and didn't think this would be a problem.) After getting the camera power wire spliced in and covered in electrical tape, I tested the camera (turn the van on, put it in reverse, back to park and turn the van off) and sure enough it sent the wireless image to the little screen in the van. BUT, when I got out of the van I got a little shock when I touched the frame. I tried this several times, always got shocked. Then I unhooked the camera completely and covered the splice area of the back up light wires with electrical tape. Still, every time I turn the van on, turn it off, get out and touch the frame, I get a little shock. I can think of only one time when I might have damaged other wires in the van. When I was fishing the power wire from the camera through the tale gate to the back up lights, I might have caught the wire hanger on some other wires, I couldn't see so I don't know for sure. A few questions. IF I did snag another wire inside the tale gate, would it result in a little static shock every time we get out of the van? If it were the positive side of some other wire, wouldn't it short the battery (and cause a bigger problem)? One friend suggested it was coincidental that I installed the camera in cold, dry weather, which is also the time of year when static electricity is common in cars. I.e. moving in and out of the car during this time of year has produced static electric charges responsible for gas pump fires. Link to comment Share on other sites More sharing options...
Hondahunter Posted November 24, 2008 Share Posted November 24, 2008 does the screen/monitor have a metal frame? the part you are touching, is it metal? Link to comment Share on other sites More sharing options...
