Repsol Posted November 23, 2008 Share Posted November 23, 2008 Okay, when I take turns, It sounds like an ocean under my rear bins. I'm not sure where the water is coming from but it sloshes around after every little turn I make. What's the problem, and how can I fix it? Quote Link to comment Share on other sites More sharing options...
diablo2dusk Posted November 23, 2008 Share Posted November 23, 2008 Okay, when I take turns, It sounds like an ocean under my rear bins. I'm not sure where the water is coming from but it sloshes around after every little turn I make. What's the problem, and how can I fix it? those bins aren't the gas tanks.. Quote Link to comment Share on other sites More sharing options...
Ksol Posted November 23, 2008 Share Posted November 23, 2008 (edited) Okay, when I take turns, It sounds like an ocean under my rear bins. I'm not sure where the water is coming from but it sloshes around after every little turn I make. What's the problem, and how can I fix it? I've heard of a couple of possibilities when it comes to this noise. One is that your rear window was smashed in the past and the glass shards fell in the space where the window slides up and down. When you turn the shards would slide side to side more or less and make a noise. Another option is your drainage pipe below the back window is blocked up and you have an excess amount of water in there somehow which obviously would sound like an ocean swooshing back and fourth when turning. Only way to really fix either is to remove all rear bins and panels and unscrew the one metal wall to see if there is anything in there. It's not even close to an easy option but it's the only way to be sure. Edited November 23, 2008 by Ksol Quote Link to comment Share on other sites More sharing options...
Repsol Posted November 23, 2008 Author Share Posted November 23, 2008 I know it's water because when we have long weeks without rain, it's not there. Once it rains, it's there for a week or two, sometimes three. It sucks. Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted November 23, 2008 Share Posted November 23, 2008 enjoy the ocean sounds and wait for it to go away? haha Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted November 23, 2008 Share Posted November 23, 2008 enjoy the ocean sounds and wait for it to go away? haha Fine until the rust starts\gets worse! Quote Link to comment Share on other sites More sharing options...
Hondahunter Posted November 24, 2008 Share Posted November 24, 2008 had the same problem, it's really not that hard to fix. the cause is the drain tubes under your plastic pieces (the 2 adjoining the third brake light cover) have become clogged. gonna have to pop those pieces off CAREFULLY and clean the hoses out. to get the water out, gotta pull the rear bins and whatever other trim pieces are necessary to get back there. IIRC you also have to unbolt the the rear window assembly. Suck the water up with a shop-vac or use a lot of rags It's really a simple process, but I've become a pro at taking the interior trim out of a sol Quote Link to comment Share on other sites More sharing options...
Mitchness Posted November 24, 2008 Share Posted November 24, 2008 had the same problem, it's really not that hard to fix.the cause is the drain tubes under your plastic pieces (the 2 adjoining the third brake light cover) have become clogged. gonna have to pop those pieces off CAREFULLY and clean the hoses out. Close. While there are drain hoses in the positions you're talking about I think Kris got it pegged on the separate drain tubes under the rear window in the cab. You'll just have to clean the silt/leaves/crud out of there before you replace your interior. Be careful how you clean them out or you could end up poking/ripping a hole in the tube which will lead to drainage inside the body and will rust the f*ck out of it. Quote Link to comment Share on other sites More sharing options...
Repsol Posted November 25, 2008 Author Share Posted November 25, 2008 Yeah, that'll definitely have to wait till summer. It's too freaking cold to be doing that now Lol. Quote Link to comment Share on other sites More sharing options...
Hondahunter Posted November 25, 2008 Share Posted November 25, 2008 Close. While there are drain hoses in the positions you're talking about I think Kris got it pegged on the separate drain tubes under the rear window in the cab. You'll just have to clean the silt/leaves/crud out of there before you replace your interior. Be careful how you clean them out or you could end up poking/ripping a hole in the tube which will lead to drainage inside the body and will rust the f*ck out of it. could you either explain or get a pic of the drain hoses you're referring to? i believe you, trust me you helped me on SS when i had the same problem! Quote Link to comment Share on other sites More sharing options...
