Brakes grind with slow stop.
xray328
Something could be loose. If the caliper comes loose, it can grind on the rotor. Pads that have no pad left will also make that noise as they chew into the rotor. You need to visually inspect your front and rear suspension and braking system, yourself.
Will do. Thanks!
I had a similar pronblem on my 97 accord this summer, changed to a softer pad and it all but eliminated it..
instead of using semi-metallic I switched to organic..
specifically I began using Wagner quickstop pads, excellent for the price..
