diablo2dusk Posted November 14, 2008 Share Posted November 14, 2008 Okay so I have a '93 del sol S. and as its not bad enough its the 1.5, but its also automatic. I plan to swap the transmission soon. What all will I need to get besides the tranny, pedals, resivior, and linkage equipemnt? IS it a fairly easy swap? Any input on this would be great. Link to comment Share on other sites More sharing options...
Hondahunter Posted November 23, 2008 Share Posted November 23, 2008 bump Link to comment Share on other sites More sharing options...
CleanGSR Posted November 23, 2008 Share Posted November 23, 2008 To my knowledge, the only member on here that has done this is Dan (90IntegraC1) but he's not on here much these days. You might try sending him a PM or searching to see if he had a thread about the swap over. Link to comment Share on other sites More sharing options...
..SSR.. Posted November 24, 2008 Share Posted November 24, 2008 Trans, flywheel, clutch, shift linkage, shift rod, shifter, master cylinder, line, slave cylinder, axles, mounts, ECU. Link to comment Share on other sites More sharing options...
diablo2dusk Posted November 24, 2008 Author Share Posted November 24, 2008 OK sounds good. i have heard though that sometimes you dont need the ECU? and it will all run fine. and how hard is it to rig up the clutch pedal? Link to comment Share on other sites More sharing options...
..SSR.. Posted November 24, 2008 Share Posted November 24, 2008 I'd get the ECU. Maps are different between the two. I forgot to mention you will need the clutch pedal. Link to comment Share on other sites More sharing options...
Repsol Posted November 25, 2008 Share Posted November 25, 2008 To my knowledge, the only member on here that has done this is Dan (90IntegraC1) but he's not on here much these days. You might try sending him a PM or searching to see if he had a thread about the swap over. I'll be the second! OK sounds good. i have heard though that sometimes you dont need the ECU? and it will all run fine. and how hard is it to rig up the clutch pedal? You don't gave to get an ECU, just get it chipped. That's what a buddy of mine did and it worked out just fine. If you have the duckies in a row, get an ECU. Link to comment Share on other sites More sharing options...
CRG7 Posted November 25, 2008 Share Posted November 25, 2008 Actually, my CRX was auto-manual swapped many years ago, before I joined up on here Link to comment Share on other sites More sharing options...
