delsol812 Posted October 10, 2008 Share Posted October 10, 2008 1998 integra ls! got it dirt for 500. was driven with no oil. guy wanted it gone.! makes loud ticking sound! thinkin it probably is crank!? replaced oil pan and bearinings! didn't help ran for a week and started up ALL OVER AGAIN Link to comment Share on other sites More sharing options...
delsol812 Posted October 10, 2008 Author Share Posted October 10, 2008 im looking at either rebuilding engine. or swapping for a v tech buy a stock b18b and boost it. looking to somethinggg with it if i get the right idea! let me know what u think and im new to honda forums! thanks Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 im looking at either rebuilding engine.or swapping for a v tech (no H for your future reference. It's VTEC) buy a stock b18b and boost it. This would be the route I'd take if it were my car and I had the money to sink into it. looking to somethinggg with it if i get the right idea! let me know what u think and im new to honda forums! thanks See quoted post above. Link to comment Share on other sites More sharing options...
delsol812 Posted October 10, 2008 Author Share Posted October 10, 2008 See quoted post above. hmm so ive heard you can get like 8psi on stock internals? Link to comment Share on other sites More sharing options...
Kastigir Posted October 10, 2008 Share Posted October 10, 2008 Rebuild the motor that's in it, with performance internals, and boost 15 pounds. Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 hmmso ive heard you can get like 8psi on stock internals? Depends on the turbo. PSI is not your determining factor, horsepower is. 6psi on one turbo setup might produce the same horsepower as 12psi on another Both are gonna have equal strain assuming both are intercooled to keep the higher heat from the smaller turbo/higher temps down. 300whp should be safe as long as it's tuned well....doesn't matter if it takes 6 psi or 12psi to get there as long as you keep things running cool. Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 Rebuild the motor that's in it, with performance internals, and boost 15 pounds. As an example (talking to the op, not you Kastigir), running 15psi on a greddy kit would get you maybe 300-320whp. 15psi on a Peakboost kit will probably be in the 450whp range or better. Link to comment Share on other sites More sharing options...
delsol812 Posted October 14, 2008 Author Share Posted October 14, 2008 As an example (talking to the op, not you Kastigir), running 15psi on a greddy kit would get you maybe 300-320whp. 15psi on a Peakboost kit will probably be in the 450whp range or better. so rebuild internals. greddy kit. and im making like...? 350whp? do i need different axles? etc? Link to comment Share on other sites More sharing options...
tallhamer88 Posted October 14, 2008 Share Posted October 14, 2008 1998 ancura integraa, --- whats that u mean Acura Integra! :thumbup: Link to comment Share on other sites More sharing options...
jerrodh Posted October 14, 2008 Share Posted October 14, 2008 If you really want results and want to mess around with turboing a car then it is the best bang for your buck. LS turbo will be a pretty mean little guy and yes you can boost on stock internals. If your mechanically inclinned and moreso have the cash to spare rebuilding the block will not only result in a stronger block but higher boost levels and more HP is another bonus. Is it a "ticking" sound like a clock or a constant "knocking" sound? Cause if its a ticking or clicking it could be an electrical issue. Undoubtful though considering your friend purposely ran it without oil lol. Link to comment Share on other sites More sharing options...
delsol812 Posted October 22, 2008 Author Share Posted October 22, 2008 If you really want results and want to mess around with turboing a car then it is the best bang for your buck. LS turbo will be a pretty mean little guy and yes you can boost on stock internals. If your mechanically inclinned and moreso have the cash to spare rebuilding the block will not only result in a stronger block but higher boost levels and more HP is another bonus. Is it a "ticking" sound like a clock or a constant "knocking" sound? Cause if its a ticking or clicking it could be an electrical issue. Undoubtful though considering your friend purposely ran it without oil lol. ya its a constand knocking sound! ya well crap happens. im either considering the turbo on stock motor. or just buying a type r motor. there just seems to be SO MANY OPTIONS with integgrAS Link to comment Share on other sites More sharing options...
